It is currently Sun Aug 03, 2025 11:24 pm
PostPosted: Mon Jan 23, 2006 9:16 am
Has anybody here ever seen a neck joint on a Tacoma? I was at a local luthier's shop the other day and noticed one that he was working on. I wish I would have taken a better look at it because the top of the neck block was routed out just like a Stratocaster neck pocket. Any one familiar with this one?
PostPosted: Mon Jan 23, 2006 9:23 am
I actually have a Tacoma (Jumbo Koa), but I've never taken the neck off it. From inside the box you see two hex bolts in the headblock. No idea what the tennon looks like, though. I will say that the heel is a bit untraditional, much wider and flatter; the profile of the heel cap is a "D" shape.
PostPosted: Mon Jan 23, 2006 9:29 am
I have never worked on or ownedd a Tacoma but It sounds likeit may be a bolt-down FB extension set-up ie. the Fretboard is completly indapendent of the top and bolted to and extesion of the neck block. Or be a knock- off of Taylor's newer set-up, a shimable neck set.
PostPosted: Mon Jan 23, 2006 9:45 am
here is a tour of the Tacoma site provided courtesy of Frank Ford at www.frets.com and Gryphon Strings. Frank sometimes contributes valuable info and advice right here on the OLF.John How38740.7409027778
