It is currently Sat Apr 26, 2025 11:40 am
PostPosted: Tue Jan 24, 2006 12:31 pm
Does anyone know of a good source to get a Drill Press Rosette Cutter?
I have seen the ones at LMI but was wondering if there was a cheaper source anywhere else....
PostPosted: Tue Jan 24, 2006 12:47 pm
8 inch type is $27 at Ace Hardware. You would have to grind the tip of the cutter to the size you need. You did say cheap?
I use the stewmac dremmel tool, but use the above for cutting out the soundhole. I purchased others for the purpose you mention, but never got around to it. Just always seem to grab the dremmel tool from stewmac.
You'd need a dremmel, a dremmel base, and a circle cutting attachment from Macdonalds.
PostPosted: Tue Jan 24, 2006 2:08 pm
Martin Guitar sells one for $18.95, and Blues Creek Guitars has one for about $15.
CrowDuck
Chris Nielsen
Soquel, CA.
PostPosted: Tue Jan 24, 2006 2:23 pm
The LMI one is expensive, but worth every penny...I just didn't feed my kids for a couple weeks and bought that one...(J-O-A-K...please DO NOT send child social services to my house! )...like Bruce I use the fly cutter to cut the soundhole, but with the setscrew and cutter arm epoxied permantly in place, and with a plywood table/bushing arrangement to keep the wobble down to a minimum.
PostPosted: Wed Jan 25, 2006 4:18 am
Here's how I ground a couple of the bits.
PostPosted: Wed Jan 25, 2006 5:13 am
It was Pete. Nice work Mr. Licis. These young bucks gotta see a pro do it and then they can, "Walk this Way!"
