It is currently Sat Jun 07, 2025 5:49 pm
Post new topic Reply to topic  [ 134 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Fri Feb 22, 2013 5:29 pm
First name: Zeke
Last Name: McKee
City: Goodlettsville
Zip/Postal Code: 37070
Looking good! I've wanted to try a bound soundhole. Maybe I should, hmmm anyhow y'all are making good progress I gotta get back to work on mine!
PostPosted: Sat Mar 02, 2013 8:13 pm
State: Tennessee
I'll have my mold and a side bending template finished tomorrow. Fellow Tennesseean Kevin Waldron makes very nice templates.
PostPosted: Sun Mar 03, 2013 7:12 pm
State: Tennessee
Finished the mold and bending form. Have a side bending.
PostPosted: Sun Mar 03, 2013 7:56 pm
State: Tennessee
Yeah baby! laughing6-hehe
Finally figured out how to bend Mahogany and then this Maple. Easy as taking a nap Sunday afternoon duh
My technique is get everything in the bender,(Steel slat, damp paper, damp side, damp paper, heat blanket, steel slat) take a shop cloth and rest your hand on the slat (rear bout) and the weight of your hand will start to bend the side around 150 degrees, take it down with hand pressure and slide your spring/caul over the form. Same on the front bout and then slowly crank down the waist.Three to four minutes max, I let it get to 300/310 and turn down the heat to 250 for 10 minutes. I leave the side in the bender for 30 minutes, or overnight.
PostPosted: Sun Mar 03, 2013 8:52 pm
First name: Zeke
Last Name: McKee
That's some good looking maple! I really need to make a bender. What plans did you use?
PostPosted: Sun Mar 03, 2013 9:01 pm
First name: Tony
Last Name: C
City: Brooklyn
Looking good clinch!
Posted using something.
http://www.CostaGuitars.com
PMoMC
PostPosted: Sun Mar 03, 2013 10:36 pm
First name: Randy
Last Name: Jones
City: Santa Clara
Zip/Postal Code: 95050
Holy smokes! Or rather, holy no smokes... those sides turned out great. Nice job!
PostPosted: Mon Mar 04, 2013 7:36 pm
State: Tennessee
Thanks for looking guys.
Zeke, I bought my bender from Bluescreek.
Tony thanks!
Randy, its sides tonight:) last night it was just one side, but I got one bent after work this evening. It is some nice looking curly maple bliss
PostPosted: Mon Mar 04, 2013 8:53 pm
Nice progress!!
PostPosted: Mon Mar 04, 2013 9:13 pm
First name: Zeke
Last Name: McKee
That's gonna be som great looking maple!!
PostPosted: Mon Mar 11, 2013 8:20 pm
State: Tennessee
Hah! Found a small crack in one of the sides gaah Anyway superglued it and it should be fine. But I decided to look at my options, what do you all think? Kind of insane curl....... and just some normal stuff. I'll probably stick with what I have. If I can get that wild set bent:)
PostPosted: Wed Mar 13, 2013 1:29 pm
First name: William
Last Name: Shafer
City: Northglenn
State: Colorado (CO)
Zip/Postal Code: 80233
Good work so far! That is some impressive looking maple.
PostPosted: Sat Mar 16, 2013 6:30 pm
State: Tennessee
Using my oh so sharp, Lie Nielsen modelers plane to radius the end blocks. I have the grain oriented with the sides. I made two different gizmos to establish the proper radius and decided planing to a line works best. duh Going to heat up the glue pot laughing6-hehe
PostPosted: Sun Mar 17, 2013 11:16 am
State: Tennessee
End blocks glued in. Side reinforcements glued in all with HHG, might get some kerfed lining glued in, might not I get really lazy on Sunday afternoon laughing6-hehe
PostPosted: Sun Mar 17, 2013 4:10 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Looking good Clinch. What is your side thickness on that curly maple? I did mine at 0.07" and it was a little tricky...but I also had a cutaway to deal with.
Doug
PostPosted: Sun Mar 17, 2013 4:57 pm
State: Tennessee
.85 no problem, but no cutaway either. However..........all that polyester side reinforcement peeled off. What are you guys using?
PostPosted: Sun Mar 17, 2013 5:11 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
I'm old school (also known as 'cheap') using a bending iron.
Doug
PostPosted: Mon Mar 18, 2013 4:28 am
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
I use wooden side braces. They're mainly just there to stop cracks running along the side.
Pablo Picasso
PostPosted: Mon Mar 18, 2013 7:01 am
First name: Zeke
Last Name: McKee
Clinch, I used a cotton/polyester bias tape on my second build and had good results and will be using it again on this one. I was pointed onto it by Mr Alan Carruth. It works great and it's flat enough that you can glue your kerfing over it without having to notch it out like the wood braces. To apply it I just use Titebond and soak the strip with it and massage the glue in with my fingers to make sure it's really soaked all the way thru. Then I just lay them in place on the sides and press them down flat and wait for them to dry. I leave them a little long and trim them to side length after they are dry. I've had no adhesion issues and my second was maple just like yours. I think if your strips were pure polyester that could be why they did not stick. If you would like the brand of the stuff I used I can try and find the package. Good luck :)
PostPosted: Fri Mar 22, 2013 7:29 am
I use the bias tape from the sewing place (Marshalls). Probably cotton polyester mix. I put tape on either side, lay the strip in HHG, then squeegee it to get the glue in there real good. When it's dry I wipe some shellac over it.
Nice work, I'm enjoying the build pizza
PostPosted: Fri Mar 22, 2013 6:23 pm
State: Tennessee
Thanks guys, I ran some "bias tape" down locally and its holding fine. I've had a cold the last week or so and have not felt like doing anything, however today at great sacrifice.......... laughing6-hehe I actually got my hands on a 1937 Nick Lucas bliss The sound can only be described as heavenly.
PostPosted: Fri Mar 22, 2013 6:46 pm
First name: Tony
Last Name: C
City: Brooklyn
You bought it? Sweet!
PMoMC
PostPosted: Fri Mar 22, 2013 7:03 pm
State: Tennessee
Ha! I wish its not for sale but I got to really check it out, play it and take a bunch of pics for reference.
PostPosted: Fri Mar 22, 2013 8:02 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
Those position markers look easy enough to replicate if you can't find them anywhere.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Fri Mar 22, 2013 8:25 pm
First name: Tony
Last Name: C
City: Brooklyn
Bummer. At least you got to check it out.
PMoMC
