It is currently Mon Aug 04, 2025 10:00 am
PostPosted: Fri Jan 27, 2006 2:08 am
Just wondering if anyone has built with Black Limba? I know it's used for electrics. It is similar to mahogany but lighter in color with some pretty varigated black lines and patterns. Should be a good acoustic tone wood.
PostPosted: Fri Jan 27, 2006 2:35 am
Find some outrageous stuff Bob and post it. I'll probably succumb along with my fellow luthier bretheren who are mostly all wood junkies.
Bob, that makes you the pusher man
PostPosted: Fri Jan 27, 2006 2:51 am
Will do John!
PostPosted: Fri Jan 27, 2006 3:02 am
This was the quality I was looking for with my primavera. If disater strikes, I'll be looking for some Limba. Are you going to carry some sets of it?
-jack handy
PostPosted: Fri Jan 27, 2006 3:14 am
I'd be interested in seeing some!
Todd Rose
Ithaca, NY
PostPosted: Fri Jan 27, 2006 3:45 am
[QUOTE=j.Brown] This was the quality I was looking for with my primavera. If disater strikes, I'll be looking for some Limba. Are you going to carry some sets of it?[/QUOTE]
I wanted to see if there was any interest before I bought any. I see that there is.
PostPosted: Fri Jan 27, 2006 3:47 am
Think about some solid body blanks.
PostPosted: Fri Jan 27, 2006 5:10 am
It's one of my favourite woods (looks-wise; I'll be building my first with it soon) for electric solidbodies (I've got a pair, getting a few more soonish), and I've heard from a few people now that it works well as an acoustic wood. In electrics, it's mahoganoy-esque tone, but with a little more high end. I'd build with it!
Here's a gorgeous McCollum acoustic:
http://www.dreamguitars.com/preowned/acoustic/McCollum_Meagh ann_M-104.htm
Gilmer's got some nice stuff, but their prices for electric body blanks are a touch on the unreasonably insane side (about 90-100 dollars for a body blank is too rich for my blood; got some from them, but also got some from another source for 55 each, and the cheaper ones are nicer, and lightly flamed, too), considering that (here anyway) Limba (white, can't find black locally) isn't that expensive.
In short: get some. Odds are high I, for one, will buy some.
PostPosted: Fri Jan 27, 2006 5:31 am
Mattia how about some solid body dimensions?
PostPosted: Fri Jan 27, 2006 6:14 am
Mattia (and Bob), looks like the Black Limba that Lance used had some curl in it. Never seen that, but it sure was pretty. Bob, can you find any like that?
PostPosted: Fri Jan 27, 2006 6:24 am
I have always wondered how this would be as an acoustic wood. Love to see some pictures.
PostPosted: Fri Jan 27, 2006 6:26 am
I've got some very light flaming (nothing like that fiddleback type curl) on the pieces I have, but I've seen several builders (check out David Myka's guitars if you like 'modern classic' electrics) who managed to find some.
Bob, a good 'standard' dimension for an electric body blank (for non-explorer type shapes) is about 14" x 20" x 1.75"-2". A Les Paul's a hair under 13" wide, and a mere 17" and change long (ditto a strat or a tele, actually..) long (IIRC), just for the record, but a bit of space to work with is always nice. 15" wide is a luxury, and some might like it (some of my semi-hollows are kinda wide). The blanks I've got are 14" x 21.5" x 2" (well, a hair under 2"). I'd even be fine with, say, 1.75" or 1.5" (if you're topping it with maple, 1.5" is fine, 1.75" for a fender-style electric without a top, 2" if you're going to carve a one-piece body).
Well, that's what I guesstimate, anyway.Mattia Valente38744.6024305556
PostPosted: Fri Jan 27, 2006 7:10 am
I have seen some with light curl.
Mattia I doubt I would be able to get 14-15" wides pieces. The stuff Gilmer has is only 7 1/2"w. So that means no bookmatch. Is that suitable? As you can see I'm not up on electric building.
PostPosted: Fri Jan 27, 2006 7:49 am
Bob,
Bookmatching is rare in solidbodys, especially if we're talking about 8/4 boards (if you could find some, though, you could probably command Ziricote-like prices for them!). However two-piece bodies with well-matched grain are very acceptable, and can produce some excellent-looking guitars.
PostPosted: Fri Jan 27, 2006 8:18 am
Thanks Carlton. That's what I thought.
I'm getting ready to finish a 000 out of limba with some pretty good curl, I'll let you know how it sounds in a few weeks. I have a plank of it about ten inches wide, 2 inches thick and 14 feet long, so I sure hope it makes good sounding guitars - It sure looks good.
                Paul Harrell
PostPosted: Fri Jan 27, 2006 9:12 am
Yep, what they said. High figure tops on electrics are bookmatched, but slip-matching is the most common thing for the bodies. With a bit of sliding 'n flipping you can get very nice matches, I feel. F'r instance, the strat and tele that've been waiting for me to get un-lazy and break out the spray gear for about 6 months now:
Came off a single large board about 9" wide, slipped and flipped the piece to get the grain 'countering' itself. The telecaster's a little less nice on the top, but only the bit that goes under the pickguard. Please excuse the pencil markings and glue all over the centerline. It's invisible, honest!
Mattia Valente38744.7173263889
PostPosted: Fri Jan 27, 2006 9:46 am
[QUOTE=CarltonM] Bob,
Bookmatching is rare in solidbodys, especially if we're talking about 8/4 boards (if you could find some, though, you could probably command Ziricote-like prices for them!). However two-piece bodies with well-matched grain are very acceptable, and can produce some excellent-looking guitars.[/QUOTE]
It is in some woods for sure!!! Many "traditional" solid body woods can be bought in 16/4 but you can't often find it the local wood store. I bought a unit of 16/4 black limba a few years back...it does make nice bookmatched blanks when I remember I have it. By the way, black and white limba are the same species, but are selected for color. Black limba markings are pigment and not spalt. Black limba weight can vary a lot from piece to piece and tree to tree...more black...more weight. It can approach heavy mahogany or walnut in weight. I'd be more than happy to sell some for ziricote prices Larry Davis38744.7413657407
PostPosted: Fri Jan 27, 2006 9:47 am
Mattia that looks very nice and a viable solution.
Paul I look forward to seeing some pic'sBobc38744.7426851852
PostPosted: Fri Jan 27, 2006 10:19 am
I might be into a few bodies. ones just big enough for an LP would serve me fine.
PostPosted: Fri Jan 27, 2006 12:44 pm
Last Name: Lewis
City: Newnan
State: Georgia
Zip/Postal Code: 30265
Howdy guys and gals-
This is a picture of a black limba acoustic set - the orange streaks are caused by bugs and it can be quite common. Hiding the bug holes are easy in this species because most of the holes are surrounded by black pigment, but not always.
I bought 4/4 and 8/4 black limba boards a few years back and about half of it had a persistent light curl - like the McCollum guitar's back and sides. The guy who sold it to me told me these trees can be pretty big - he showed me a fairly well quartered 16/4 piece that was 20"+ wide and about 15' long. At the time he was selling 8/4 flatsawn honduran mahogany for $7.50 a boardfoot and 8/4 quartersawn black limba was $4.75 a boardfoot. Even though this wood is in vogue with electric builders it is still fairly inexpensive. It does sound like a pretty good alternative acoustic wood. If I didn't have so much of it already I would buy some from the Zootman. Also, if you can use this for the back and sides why not for the neck on acoustics too. Just my $0.02.
Peace-
John Lewis
PostPosted: Fri Jan 27, 2006 3:39 pm
I've got an acoustic set all ready to go, can't wait to get into it!
Mark Swanson
Swanson Guitars
PostPosted: Fri Jan 27, 2006 4:10 pm
Hey John, that is b -u- t full wood you got there, did you think of a theme for that guitar ?
PostPosted: Fri Jan 27, 2006 11:56 pm
Last Name: Lewis
City: Newnan
State: Georgia
[QUOTE=Serge Poirier] Hey John, that is b -u- t full wood you got there, did you think of a theme for that guitar ?
Serge[/QUOTE]
Serge-
This was a set on eBay that someone else won (they outbid me). I just saved the picture because it was so pretty. I do have some wood that is similar but it doesn't have orange streaks that big. If I can get into my stash and take pics of it, I'll post them for you. If the Zootman starts selling Limba sets do get some - it really is nice stuff.
Peace-
John Lewis
PostPosted: Sat Jan 28, 2006 2:46 am
Coming Soon Blaaaaaaaaaaaaaaack Liiiiiiiimba!
