It is currently Mon Aug 04, 2025 9:57 am
PostPosted: Sat Jan 28, 2006 1:09 pm
I am doing my first real neck reset on an archtop. I did not find shims in the pocket when i steamed off the neck. I now have shaved the heel and have it ready to glue. THe neck moves a bit side to side, but not much. Need there be shims put in to mkae it totally imobile? If I clamp and glue her in I don't think she will move. Thoughts?
DEnnis
PostPosted: Sat Jan 28, 2006 1:42 pm
Resets are a great way to learn and practice youe repair skills. I have used so many things when I started. One of the easiest ways to make shims is hand plane curls.
   You want your shims to have the neck tight. I like to have the neck about .010 high so I can press it tight into the block.
    Keep an eye on the heel and top so you can see what to shim and where.
Good luck
john
PostPosted: Sat Jan 28, 2006 1:48 pm
John,
"Hand plane curls" What a wonderful idea!! So simple.
Just one question, how do you flatten them out?
Crowduck
Chris Nielsen
Soquel, CA.
PostPosted: Sun Jan 29, 2006 1:26 am
I think I saw an article somewhere that the guy used a household iron to flatten out the plane shavings.
PostPosted: Sun Jan 29, 2006 2:40 am
Hi Dennis, Yes shims, especially on an archtop with a floating fingerboard extension. Since the fretboard is not glued on a lot of archtops there is a lot of leverage working against the set if it has a short dovetail. Vegas are the worst!! I just sand some scrap wood to the right thicknesses glue them in and clamp.
Evan
Users browsing this forum: Bing [Bot] and 16 guests
