It is currently Mon Aug 04, 2025 6:13 am
PostPosted: Mon Jan 30, 2006 3:50 am
Was curious what adhesives everyone uses for gluing carbon fiber rods into their guitar necks (mahogany in this case). Thanks in advance for your thoughts.
Kevin
PostPosted: Mon Jan 30, 2006 4:32 am
   I'm no expert but I sould think epoxy or CA would do the trick. Maybe even polyurethane, although I'd be careful with the foaming. Cheers.
PostPosted: Mon Jan 30, 2006 7:41 am
I've used epoxy, found it fiddly and messy (only had 5 minute stuff), Mario turned me to Polyurethane, which works fine. Needs good clamping, but a CF rod's not particularly difficult to clamp, really. Cleans up well (acetone), and the foam that does stick around chisels off well.
PostPosted: Mon Jan 30, 2006 8:25 am
Ya, I use Gorilla Glue, it does foam out, but a little scraping takes care of that.
PostPosted: Mon Jan 30, 2006 9:11 am
Will that plastic binding glue from LMI work?
-jack handy
PostPosted: Mon Jan 30, 2006 9:18 am
I've always used Titebond. I use the LMI rods and their router bit and the fit is very snug indeed. I just spread some Titebond along the slot, push down the rods, cover with baking parchment and then clamp the whole thing down. Has worked fine for me.
PostPosted: Mon Jan 30, 2006 10:52 am
30 minute epoxy. There's not much to do other than apply the epoxy in the slot, insert the rod into the slot (it should be tight), put a waxed paper caul over the top and clamp for a few hours...unless, of course I'm missing something!
PostPosted: Mon Jan 30, 2006 1:27 pm
I use golf club shafting epoxy on CF rods, truss rod and FB. It will release with a (hot) heat gun or clothes iron too.Tim McKnight38747.8946990741
tim...
