It is currently Sun Sep 14, 2025 7:36 am
PostPosted: Thu May 30, 2013 1:40 am
First name: Todd
Last Name: Johnson
I inherited this 1940-ish fairly cheap wartime-patriot themed archtop. I don't know who made it, and I doubt it has much value, even to collectors of these types due to the damage on the top.
The neck has a serious bow and I don't see an adjustable truss rod so I assume it has a steel reinforcement bar instead, or perhaps nothing. Can this much bow be fixed?
pictures here: https://www.dropbox.com/sc/fi1y0oz7sxrdlpn/Mna8SvI1bk
I've never worked on an acoustic guitar before and this might be a great learning project. I'm pretty handy with wood, grew up in my father's woodwork shop. I've been reading a lot and watching lots of videos about acoustic repairs and I'd like to take a stab at it.
Your thoughts?
..Todd
PostPosted: Thu May 30, 2013 8:06 am
First name: Big
Last Name: Jim
Yes it can be fixed . My thoughts would be to remove the neck and take fret board off , using steam and a clamp slowly bring it back to flat . Then I would route a channel and install carbon fiber rod to help it stay flat . Reapply fret board and reset the neck ...
That having all been said ... I'M NOT A PRO . Someone else may chime in here with a much better approach
PostPosted: Thu May 30, 2013 12:37 pm
First name: Todd
Last Name: Johnson
Thanks WudWerkr.
I wonder what would be a suitable way to apply steam in that situation. Put the whole neck into a steam box? Or a more subtle application.
..Todd
PostPosted: Thu May 30, 2013 3:04 pm
Tai, I used to fix warped or even twisted necks with the judicious application of heat.
I've used heat lamps, or heating pads wrapped in a towel.
Don't get it so hot that the finish softens - go slow.
Good rule of thumb: if you can't touch it, it's too hot!
Get it warm slowly, and clamp it gently - let cool, and unclamp after 24 hours.
May take a couple times to get everything just so.
DO NOT walk off while heating the necks. I know a guy who turned a Les Paul neck into charcoal by leaving the shop while heat-soaking the wood.
PostPosted: Thu May 30, 2013 4:08 pm
First name: Todd
Last Name: Johnson
Thanks Chris. Heat is certainly a bit easier to provide and localize than steam (charcoal notwithstanding).
Another question... what bracing patterns are considered effective for archtops? I've seen lots of information on the internet about bracing flattop steel string guitars, not so much about archtops w/f-holes.
..Todd
PostPosted: Tue Jun 04, 2013 9:18 am
First name: Coe
Last Name: Franklin
City: Decatur
Todd, it may be a shot in the dark, but check out the Kay Guitar Co. in Chicago, Ill.
It has many signs that I see on an old "Cowboy" themed flat-top guitar from that same time (1941) that I have in waiting, and waiting, and waiting...
For the restoration, that is.
Coe
PostPosted: Tue Jun 04, 2013 4:53 pm
First name: Todd
Last Name: Johnson
Thanks Cocephus,
I've only ever found two other examples of Victory guitars on the internet. One was identical, and one was a flat top with the same red, white and blue theme. Very rare. But I'm not really too hung up on identifying its maker or researching its lineage, since it's so cheaply built. I am most interested in making it play nicely as a repair project - even if just to keep it out of the landfill.
Not sure if refinishing it will destroy any mojo/value it may have otherwise retained, since the top has initials and peace signs scratched into it. This guitar has been in our family since the 50's at least, so I and my brothers will take full responsibility for ruining the soundboard in our misspent youth.
One oddity about this is that the guitar has been here in Canada with our family since it was very young, and a patriotic red, white and blue (American) theme is clearly not something you would normally have seen in Canada. Our wartime efforts, if I remember correctly, were primarily in cahoots with the British military, not so much the US military (but I could be wrong). It's origin is a bit of a puzzle.
I suppose some multinational retailer like Sears Roebuck might have imported it and sold here it, disregarding its foreign patriotic design theme.
..Todd
PostPosted: Tue Jun 04, 2013 11:46 pm
First name: Todd
Last Name: Johnson
Silly me, I put my glasses on and realized the ripply maple back and sides are a just a painted-on faux ripple effect. Had me fooled, though I could never subconsciously reconcile the cheap overall construction with a ripply maple back and sides. It makes more sense now.
I also took a closer look at the neck tonight. The neck relief is not as bad as I thought (1/16th in). The extremely high action is happening because the neck heel has lifted away from the body slightly. So a full neck reset, fret board levelling and refret will be required to make this playable again.
This is looking more and more like a luthier practice piece rather than a quirky historical memento. I'm pretty sure it will never sound very good.
..Todd
PostPosted: Tue Jun 04, 2013 11:54 pm
First name: Todd
Last Name: Johnson
I've dealt mostly with electric guitars until now so I have questions about this type of guitar...
What fret size (range) is typically used on archtop acoustics?
What string gauge (range) is typically used for archtop acoustics?
Are there any typical archtop bracing layouts kicking around the internet? I've seen a couple diagrams but I don't know if they are normal. I'm just a bit curious about that. I doubt I will reconfigure this guitar's bracing.
..Todd
PostPosted: Wed Jun 05, 2013 9:01 am
First name: Big
Last Name: Jim
Camping Guitar
PostPosted: Wed Jun 05, 2013 10:49 am
First name: duh
Last Name: Padma
Yo Tod,
ain't no such thing as typical or standard when it comes to strings and frets...is more like a personal persuasion kinda situation, you know, like pink underwear.
Bracing in arch builds is either parallel or " X " Thicker tops with " X " bracing tend to be softer or mellow in sound where as thin tops with parallel braces tent to project with a louder voice.
PostPosted: Wed Jun 05, 2013 3:04 pm
First name: Todd
Last Name: Johnson
WudWerkr wrote:
Camping Guitar
kindling ;)
..Todd
PostPosted: Sat Sep 07, 2013 1:47 pm
so the previous commenter who was trying to lead you to the maker of the instrument was trying to inform you as to sources of info such as internal bracing, fret size, etc. there is a 99% chance there are several other "brands" of guitars with the exact same construction, only a different label on the headstock. If you prefer get a small mirror and flashlight and have a look.
