It is currently Fri Jul 18, 2025 5:19 am
 Post subject: Is this Claro?
PostPosted: Fri Jun 21, 2013 9:59 pm
First name: Tom
Last Name: Phillips
City: Arcata
Was given this board, got one set out of it which I really like. 30 years old or so, I'm told some flavor of Walnut. RIngs well, slightly better than my Black Walnut. Sides have a small knot, but otherwise equally beautiful. My guess is Claro?
Either way, thinking it'll make a swell L-00.
 Post subject: Re: Is this Claro?
PostPosted: Fri Jun 21, 2013 10:12 pm
First name: Stuart
Last Name: Gort
You could just say it was Claro and nobody would argue...looks like it. Most of the Claro I've gotten was darker but I have limited experience with it. It should be easy to easily identify as Walnut at least...by the smell.
StuMusic
PostPosted: Fri Jun 21, 2013 10:13 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
It looks like Claro to me.
PostPosted: Fri Jun 21, 2013 10:24 pm
First name: Randolph
Last Name: Morris
Looks like orchard Claro to me. Not all Claro is darker. Color is dependent on the mineral content of the soil the trees grow in. You can see the English walnut graft at the right side of this set - a dead giveaway.
PostPosted: Fri Jun 21, 2013 10:42 pm
First name: Tom
Last Name: Phillips
City: Arcata
Ah, not knowledgeable enough to recognize the graft. Thank you. There is a small crack/check near the graft that will be out of the pattern, and a small worm hole or two in the same neighborhood. Other than that, any fatal flaws?
PostPosted: Sat Jun 22, 2013 10:40 am
First name: Tom
Last Name: Phillips
City: Arcata
Definitely not cardboard. My first guitar used a figured Hog back that DID tap like cardboard, and it turned out pretty amazing. Can't seem to get it back from my buddy, so go figure... I also have these two 000 babies on the bench, made from Otterhound's Black Walnut, that also does not tap like cardboard. Anxious to see how they sound!
