It is currently Mon Aug 04, 2025 7:45 am
PostPosted: Fri Feb 03, 2006 9:27 am
Electric trading company has some good prices on new explosion proof fans if anyone is interested.Rod True38751.7273958333
PostPosted: Fri Feb 03, 2006 9:56 am
Rod,
Those are good prices. I've been keeping an eye out for a "deal." I think I'll continue to wait for someone to be giving one away on ebay. Just wondering whether you have used one of these and what you think. What size do you have and how did you set it up.
Joe Volin
PostPosted: Fri Feb 03, 2006 10:01 am
I was looking at those the other day. Those are pretty much the best prices I could find too. It's still expensive, but when I think about all the other moneys I've spent so far, another 500-600$ won't matter all that much in the long run. It just seems I have a lot of other things to buy before justifying the expense...
   Shaw was right, money is the root of all evil!!!
PostPosted: Fri Feb 03, 2006 10:44 am
note that you have to buy the junction box, and the shutters to put one of these into operation. you may also have to get a guard depending upon your installation configuration.
PostPosted: Fri Feb 03, 2006 11:04 am
Well, here are some pics of my humble little spray booth, it's not totally up to code (I don't have explosion proof lighing, just one twin tube florecent lamp) but the fan is explosion proof.
So I have been saying in some previous threads that I have made a semi-knock down spray booth. Well the "semi" part is the two doors which swing into the walls. This still gives me room to use my sander.
Now with the doors open
Here is the fan housing I made
With a high end furnace filter to trap most of the overspray (ya right).
And the inside of the housing is the explosion proof fan and the exit hole.
And some shots of a guitar being refinished (this is #3, and the first finish realy sucked, this one has 6 coats of nitro, a couple more than it'll be ready to level I think)
There you go.
PostPosted: Fri Feb 03, 2006 11:09 am
Joe, I don't have one of the electric trading company fans, I have one similar, it's a leason brand, 16" dia, rated for 2800+/- cfm (I think, It's on the housing, I'll recheck later). This thing realy works well for my little spraybooth, anthing bigger (booth that is) and I'd need a bigger fan I think.
PostPosted: Fri Feb 03, 2006 11:15 am
Rod -- I gotta learn how to do links    Here's a source in the Toronto area http://www.leaderfan.com/
I see below you already have one --
BTW: Nice lookin guitar! How's the little one doing?Anthony Z38751.8035532407
PostPosted: Fri Feb 03, 2006 11:20 am
Anthony, to add a link, use this button
Than follow the instructions, copy and past the link into the second pop up box.Rod True38751.8064814815
PostPosted: Fri Feb 03, 2006 11:22 am
He's doing well thanks for asking, we are sleep deprived but that's to be expected. Rod True38751.8074768518
PostPosted: Fri Feb 03, 2006 5:43 pm
Rod,
That is a very nice set up. I was thinking more along the lines of the knock down setup that Jeff Jewitt has in his finishing book. Nice job! Are the doors more to keep the dust out or do you think they are necessary to keep the fumes in?
Joe
PostPosted: Sat Feb 04, 2006 5:38 am
Great set up Rod and gorgeous guitar too!
PostPosted: Sat Feb 04, 2006 7:01 am
Joe, the doors do both, or at least that's the idea, there is very little dust problems when spraying at this point so I think the doors have sealed alright. I leave the fan running for about 10-15 mins after spraying so the initial fumes are mostly exhausted. But of course, there is still off gassing so I have been keeping the doors closed and the rest of the shop is mostly fume free. Turning the fan on periodically to clear the fumes from off gasing.
Thanks Serge.
PostPosted: Sat Feb 04, 2006 11:04 am
I keep looking for the "cheap" solution...A belt driven fan with the motor mounted on the outside. I can't find one. Anyone know where?
