It is currently Mon Sep 15, 2025 9:00 am
 Post subject: Truss rod question
PostPosted: Sun Sep 22, 2013 3:26 pm
First name: Kent
Last Name: Wilkinson
City: New Carlisle
State: Ohio
Zip/Postal Code: 45344
Another neck question. I am new to necks. I am going to order some truss rods from Stew Mac. Any suggestions on what I should order?
 Post subject: Re: Truss rod question
PostPosted: Sun Sep 22, 2013 5:12 pm
First name: Hugh
Last Name: Evans
Depends on what you want them to do. Basses sometimes use two rods, while others use laminated necks along with a single truss rod. Do you want a double or single acting design?
Through stewmac, hot-rods seem to be the most popular for beginners and many pros swear by them (except for those of us who have shops equipped with a CNC router. I make my own one-piece double acting truss rods (based on a design used by PRS) by using two anchor points... It's almost as easy as installing a plain single acting rod. If you're interesting in going that route send me a PM and I can answer your questions.
PostPosted: Sun Sep 22, 2013 6:08 pm
First name: Kent
City: New Carlisle
State: Ohio
It will be for telecaster style guitars.
PostPosted: Mon Sep 23, 2013 6:24 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
A lot of people prefer the truss rods from Allied because they don't require as deep of slot, but on the other hand, there have been issues with some of the Allied rods failing.
Perhaps someone knows of rods similar to the Allieds in size but more reliable?
Kevin Looker
I'm not a luthier.
PostPosted: Mon Sep 23, 2013 7:44 am
I have been using Allied rods with no issues to date. However, several weeks ago I had the opportunity to visit the Martin 1833 store in Nazerath and picked up a couple of the new double acting rods. I really like the looks and several reputable folks here vouch for their reliability. They are also a bit easier to install as they don't require a wooden spline, you just put it in the slot with tite bond then install the fretboard. I'll be using these on my next builds.
PostPosted: Mon Sep 23, 2013 8:17 am
Last Name: Brumbaugh
I buy rods from Grizzly and LMI. They appear to be the same thing. I am not a fan of the hot rods from Stew Mac because the route has to be deeper and they are an odd width, so if you want a tight fit, you have to buy their overpriced router bit.
If you are wanting a single acting rod, like a telecaster has, that's altogether different. I have never bought one of those, but if you have the right tools, they seem fairly simple to make.
