It is currently Sun Sep 14, 2025 3:18 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2
PostPosted: Sat Jun 26, 2010 11:41 am
Thanks Trev. I wound up having to offset both out and down by the radius of the bit. That doesn't seem right so I must have been doing something wrong.
I couldn't figure out how to get the bit to enter the workpiece from the bottom of the part on both sides of the neck so I created a region for each half of the neck. This allowed me to rotate the angle of cut 1 degree for each half so that the outside cuts were parallel to the edge of the neck
I've been using Visualmill for about two weeks now and am finding it a revolution compared to what I was using. I see the value in RhinoCAM now. It's a bit of a pain to switch back a forth. I suspect you'd need a work station type computer to keep things moving at a reasonable speed though.
PostPosted: Sun Jun 27, 2010 11:55 am
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
The Z height issue you are running into may also depend on the height that you have drawn the part at. I always draw the bottom of the part at Z=0. I also split the toolpath into a treble and bass half, as you've done. I haven't angled the toolpath in the past, but that's a cool trick...I'll probably work that in next time I run a carve. The only way that I know of to control where the cut starts in RhinoCAM is to change the "Start Side" from top to bottom (this option is in the 'Parameters' section of the toolpath definition).
I like RhinoCAM. The one thing I don't like, is that if I upgrade Rhino, I'll have to upgrade RhinoCAM as well (I'm running Rhino 3.0 still). I'll probably hold off until the rendering gets better...Rhino 5.0 might be the ticket. The display accuracy is probably one of the few complaints I have about Rhino...
Trev
http://www.PeakeGuitars.com
PostPosted: Sun Nov 03, 2013 4:30 am
First name: Hilko
Last Name: Nackaerts
Country: Belgium
Parser wrote:
In the next couple of steps, I move the edit points for this spline along the Z and X axes in order to make it round as shown.
Great tutorial, many thanks. Got one problem:
Think there is an image missing would it be possible to add it again please?
Respect!
FB Page
PostPosted: Sun Nov 03, 2013 7:54 am
First name: Trevor
Last Name: Lewis
City: Crownsville
Hi Marzano, just keep scrolling down on the first page and you'll see a response with the pics back in it. I'm glad it helped!
Trev
PostPosted: Sun Nov 03, 2013 8:04 am
First name: Hilko
Country: Belgium
Trev
Cheers Trev, I know and did scroll down, it seems that there's a picture missing in that post (or I'm missing something)
EDIT: link "http://www.peakeguitars.com/images/rhinocarve/rhinonecktut7-hscurve2.jpg" is not working.
FB Page
PostPosted: Thu Dec 26, 2013 10:35 am
Unable to see most of the attachments -- none in the original post?? is this a browser or settings issue?
PostPosted: Thu Dec 26, 2013 11:39 am
First name: Hilko
Country: Belgium
Page one stroll down 2/3 the page and you'll see all the attached shots. No problem here.
FB Page
PostPosted: Fri Dec 27, 2013 3:54 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
This tutorial shows one way to do it - surfacing is an art in itself and like most, there is not one right way. 4,000+ views, wow!
Trev
