It is currently Sun Sep 14, 2025 2:43 pm
PostPosted: Tue Feb 04, 2014 2:15 pm
First name: Big
Last Name: Jim
Have a young Man who has brought me a Gibson J35 Acoustic Electric ... The Neck Is Twisted , and he says getting worse . I called Gibson , they wont sell me a Replacement neck . Any Suggestions ?
 Post subject: Re: Gibson J35
PostPosted: Wed Feb 05, 2014 8:24 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Make one. I see Gibson acoustics every once in a while that have had replacement necks made and installed and I am known to make the odd replacement neck when the situation arises.
Brian
PostPosted: Wed Feb 05, 2014 9:31 am
First name: Big
Last Name: Jim
Whats it going to do to the Value of the Guitar not being original ? Making the Neck isn't an issue , its Keeping the Value I'm questioning
PostPosted: Thu Feb 06, 2014 8:41 am
Last Name: Howard
City: Magnolia
State: Delaware
Value is already gone...... with a badly warped neck it is only a wall hanger, a piece of art. Make a faithful enough reproduction and most will never know. You can salvage the face plate from the headstock and reuse it.
Brian
PostPosted: Thu Feb 06, 2014 3:14 pm
First name: Big
Last Name: Jim
Update , Looking down the neck from head stock , it does appear to have a slight twist . HOWEVER , when I did some checking with Parallel's its not twisted . The Bridge on the J35 is an angled bridge and the Saddle has been ground down on an angle as well " not factory " the whole thing creates an optical illusion . oops_sign
Because someone messed with the bridge the action above 12th fret at 1st string is .040 and at 6th is . 058 and he wonders why it buzzes ... Also , whoever messed with it before loosened the truss rod nut to the point it was about to fall off ..... gaah New Saddle ordered ... Reset to proper string height and a little truss rod action and it should be in excellent shape. [:Y:]
Btw , where he had it worked on before was a "Reputable " Guitar store ... Sad
PostPosted: Fri Feb 07, 2014 8:37 am
Last Name: Howard
City: Magnolia
State: Delaware
Glad it worked out well.
Brian
PostPosted: Fri Feb 07, 2014 12:54 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Way to diagnose, Dr Wud! Guy's lucky he found you.
PostPosted: Fri Feb 07, 2014 1:43 pm
First name: Tony
Last Name: C
City: Brooklyn
I think you should figure out how to warp the neck so you can practice fixing it. Or don't. You know...whatever.
http://www.CostaGuitars.com
PMoMC
PostPosted: Fri Feb 07, 2014 4:04 pm
First name: Big
Last Name: Jim
I LIKE the way you think !! laughing6-hehe laughing6-hehe
Be honest with you when I realized what situation was I felt a Little embarrassed that I didn't catch it faster . :oops:
PostPosted: Mon Feb 10, 2014 9:09 am
First name: Big
Last Name: Jim
http://www.facebook.com/photo.php?v=422688511194515&set=vb.100003601087065&type=2&theater
Bridge and saddle repaired , Truss rod adjusted , string height set and . Very satisfied customer [:Y:]
