It is currently Sat Jun 07, 2025 12:09 am
PostPosted: Mon Mar 31, 2014 12:40 pm
First name: D
Last Name: S
Well, I reckon I'm in.
I have a chunk of a Pecan log and my Mesquite should be dry in time.
I plan to make a simple electric.
The body face will be end grain, I'm still trying to figure out how to keep it in one piece.
Thanks Jay,
Dan
Oh yeah, This,will be my 9th electric.
wah
Wah-wah-wah-wah
Wah
PostPosted: Thu Apr 03, 2014 7:21 am
First name: joseph
Last Name: sallis
City: newcastle-upon-tyne
State: tyne and wear
Zip/Postal Code: ne46xe
Country: UK
end grain face, one piece electric.... can't wait it see it...
We are all in the gutter but some of us are looking at guitars.
PostPosted: Thu Apr 03, 2014 6:28 pm
First name: D
Last Name: S
Here's a picture of the Pecan slab, some Mesquite, and a thing I made to surface the Pecan.
I think I'll slice the slab in half and shove a piece of Mesquite between the top and back plates.
I'm afraid of the Pecan coming apart at the grain lines.
wah
Wah-wah-wah-wah
Wah
PostPosted: Thu Apr 03, 2014 7:27 pm
Wow, can't wait to see that as a guitar!
PostPosted: Sun May 04, 2014 6:12 pm
First name: D
Last Name: S
My plan is for a short squatty look.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun May 04, 2014 6:53 pm
First name: Patrick
Last Name: Hanna
State: Missouri
I would be afraid, too, as I can already see some checks working their way in from the edges. The potential problem is this: You appear to have a log segment with the center pith right in the middle. This makes an interesting visual at the moment, but I worry that it won't be stable--that, as it shrinks and dries further, the inevitable checks and cracks will show up. I am not sure how to arrest this process, but I know that bowl turners have a method for doing it. I would go to some lathe and bowl turning sites and consult with the people there about how to capture a center pith and arrest the shrinking process before I went any further on the guitar body.
I would follow their advice. Seriously, please look into that. I don't think your worry should be about the grain lines separating. The separation will manifest itself as cracks radiating out from the center (the bull's eye) of that cross cut section.
PostPosted: Sun May 04, 2014 8:12 pm
First name: D
Last Name: S
Thanks for the advice!
I'll look into bowl turner's strategies.
I think the checks you are seeing are pencil marks I made around the perimeter.
I had a thought to insert dowels around the perimeter but have decided not to.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun May 04, 2014 8:51 pm
First name: D
Last Name: S
Cut up a small Mesquite log last weekend.
Pretty amazing stuff. It can develop checks while drying, but it does not warp or twist at all.
I painted the ends and stickerd it up in the garage.
These pieces are nearly quarter sawn and should make nice fret boards.
A wet log 12" diameter x 4' long weighs close to 150 lbs. The sapwood must be removed quickly due to borers.
wah
Wah-wah-wah-wah
Wah
PostPosted: Mon May 05, 2014 8:48 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Those are some pretty FB blanks, Dan. How much drying do they need to do from log to FB?
I'm looking forward to following your build, and how you deal with any issues with the body.
Keep us up to date! [:Y:]
Alex
PostPosted: Mon May 05, 2014 12:27 pm
First name: D
Last Name: S
Alex
Thanks, Alex!
I'm going to give them two months to dry and then slice one to see if they are dry. My garage is already up to 80F and I have a fan blowing on them. Kinda hard to slow dry stuff in Texas.
BTW, I made the router jig per your instructions a while back. It works great.
Sanding the end grain is going to be a long process.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Fri Jul 18, 2014 12:41 pm
First name: D
Last Name: S
My Mesquite is dry.
I have not decided yet to go with Mesquite or Pecan fretboard.
Maybe a combo.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Aug 09, 2014 5:14 pm
First name: D
Last Name: S
After three weeks of being layed out with a back injury, I finally started back on the build.
I hated to do it, but I cut the body into two pieces so I can add a Mesquite core.
I am concerned about structual integrity. Good thing I have a sharp hand saw.
I have some awesome curly Ash from a backyard tree I cut, but I'm not sure how to use it and avoid gaudiness.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Tue Aug 19, 2014 9:43 pm
First name: D
Last Name: S
I made a little progress despite the 100F temperature.
I cut out a piece of the body core that I will use as a "drawer" with volume knob and jack mounted to the outside edge surface.
I glued the outside body plates to the core. The core is curly Ash sandwiched between Mesquite.
I spent most of the sawing and planing logs to make the core and almost gave up on it.
I'm still working out the headstock shape.
Dan
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Aug 23, 2014 5:54 pm
First name: D
Last Name: S
Sanding and shaping the body.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Aug 23, 2014 8:10 pm
First name: Jeff
Last Name: Dillard
I like the drawer , is that original or have you seen it before ? That pecan is beautiful!
PostPosted: Sat Aug 23, 2014 10:36 pm
First name: D
Last Name: S
thanks Jeff,
No, I have not seen the drawer before, but I'm sure someone has done it.
I wanted the volume on the edge rather than the top.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun Aug 24, 2014 1:41 pm
First name: Jeff
Last Name: Dillard
man i love originality, wish i had more of it
PostPosted: Sun Sep 14, 2014 4:12 pm
First name: D
Last Name: S
Got a bit done on the neck and headstock veneer.
Don't know if I will finish in time.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sat Sep 27, 2014 5:46 pm
First name: D
Last Name: S
I just finished an unplanned Tele build.
Look's like I will not have enough time to finish the challenge build.
[uncle]
Dan
wah
Wah-wah-wah-wah
Wah
