It is currently Sat Jun 14, 2025 10:47 pm
PostPosted: Mon Apr 21, 2014 10:13 am
First name: Stuart
Last Name: Gort
She's done.
Neck strip is Maple and Black Cherry. Fretboard is Rosewood. Body panels are African Mahogany.
I made the bridge and other hardware. Tuners are Gotoh 510's and pickups are Lace Sensor Drop & Gains...GREAT pups for this.
This guitar as shown weighs 6 lbs. 6 oz.
StuMusic
PostPosted: Mon Apr 21, 2014 10:15 am
First name: Stuart
Last Name: Gort
and...
StuMusic
PostPosted: Mon Apr 21, 2014 10:19 am
Love it. I would like to know more about the bridge / hardware construction.
These users thanked the author lactose for the post: Stuart Gort (Mon Apr 21, 2014 2:58 pm)
PostPosted: Mon Apr 21, 2014 11:01 am
Hit another one out of the park, Stuart!
These users thanked the author Chris Pile for the post: Stuart Gort (Mon Apr 21, 2014 2:58 pm)
PostPosted: Mon Apr 21, 2014 12:23 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Lots of times, solid body guitars don't capture my interest. But there is something about yours that really gets my attention. There's a strong "cool" factor there. I like the way you have made all the appointments harmonize visually. The knobs echo the position markers and the string tees. They, in turn work so well with the pickup covers, the bridge, etc. These are very nice visual details that bring the whole instrument together for me. I dig it! A lot!
Don't poke your eye out with that headstock! But you could use it to nudge another player away from the microphone.
Patrick
These users thanked the author cphanna for the post: Stuart Gort (Mon Apr 21, 2014 2:58 pm)
PostPosted: Mon Apr 21, 2014 1:51 pm
Last Name: Sollod
Stuart, That is very visually appealing and creatively done. That is very impressive that you make the hardware. That also makes it unique. You can't get a guitar like that anywhere else...
www.swiftcreekguitars.com
These users thanked the author sdsollod for the post: Stuart Gort (Mon Apr 21, 2014 2:58 pm)
PostPosted: Mon Apr 21, 2014 2:48 pm
Very nicely done, design through fit and finish.
These users thanked the author jfmckenna for the post: Stuart Gort (Mon Apr 21, 2014 2:58 pm)
PostPosted: Mon Apr 21, 2014 2:55 pm
First name: Stuart
Last Name: Gort
The bridge essentially functions like a tune-o-matic with minor differences.
The pocket under it has two holes drilled down into the body aligned with the adjustment holes pictured. Long set screws are threaded into those holes....the wood itself retains the thread. The tops of those screws are received by the bridge body and access with an allen wrench is provided through the visible holes. In other words...putting an allen wrench into the hole turns a set screw which you can't see and raises or lowers that end of the bridge.
The bridge body is 6061 aluminum. The silver pins which the strings ride on are 17-4 stainless steel. They are press fit into the aluminum saddles.
StuMusic
PostPosted: Mon Apr 21, 2014 7:32 pm
First name: Ben
Last Name: M
City: Bristol
State: RI
Very classy! I really like the tailpiece/"ferrule plate" design. How is that whole system held together?
These users thanked the author Beazy for the post: Stuart Gort (Mon Apr 21, 2014 7:45 pm)
PostPosted: Mon Apr 21, 2014 7:45 pm
First name: Stuart
Last Name: Gort
Both pieces on the front and back press fit into their cavities...not very tight on the front piece so you can pull it out with your fingers. From that cavity you can tap out the back piece with a long pin. Both pieces could have fit in there looser though...and string tension alone would hold them all in place.
StuMusic
PostPosted: Mon Apr 21, 2014 8:32 pm
Stuart, that has "you" written all over it...!
Love it, especially the hardware that you made.
These users thanked the author Don Williams for the post: Stuart Gort (Wed Apr 23, 2014 10:42 am)
PostPosted: Mon Apr 21, 2014 9:52 pm
City: Tyler
Unique and well designed. Very nice.
These users thanked the author Glen H for the post: Stuart Gort (Wed Apr 23, 2014 10:42 am)
PostPosted: Tue Apr 22, 2014 12:18 pm
First name: Stuart
Last Name: Gort
Thanks all.
I just got finished ordering some Sperzel tuners for the next three of these.
Those Sperzels are satin black like the hardware I made....not shiny black like the Gotohs. They can be ordered with silver locking nuts on the back so I get the two-tone black and silver thing going too. Plus they can be ordered with staggered tuning post heights...so bye bye to the string tees...which I hated to have to use. I'm kind of stoked about this.
StuMusic
PostPosted: Tue Apr 22, 2014 11:51 pm
Stuart, that's some really nice original work. Great job!
These users thanked the author Jim Watts for the post: Stuart Gort (Wed Apr 23, 2014 10:42 am)
PostPosted: Fri Apr 25, 2014 6:39 am
State: AR
I like it Stuart.
Very clean and beautiful design.
String trees and cavity cover are excellent too.
It does appear that the strings may be contacting the bridge- curious about that- and really like
the bridge design.
Ace.
PostPosted: Fri Apr 25, 2014 5:50 pm
First name: Stuart
Last Name: Gort
Sandywood wrote:
I like it Stuart.
the bridge design.
Ace.
Close...but not touching...and I got a little lucky about that.
The tailpiece was up higher in the original design but without little grooves in the saddle pins the strings would pull off of the pins too easily when bending hard. So I reduced the height of the tailpiece to make a higher angle toward the bridge...and I filed little grooves in those saddle pins by hand. Totally took care of that issue but yes...the strings ended up pretty close to touching the bridge.
Next time I get those pins made I'll have little, rounded grooves turned into them and then make new saddles that are .1" higher. Then the whole bridge body will adjust lower...and therefore...more clearance.
Btw....I made five of these prototypes but only cut the bridge cavity in this one since I wasn't 100% sure it would intonate properly in this position. But the saddles ended up EXACTLY as designed because the nut slot, all the frets, and the bridge cavity were all cut at the same time. That kind of proved that the theoretical fret positions using "stretch compensation" are valid. Since making this one I finished cutting the other four and I'm getting a second one ready to play.
StuMusic
PostPosted: Sat Apr 26, 2014 5:45 pm
First name: Rick
Last Name: R
Wow - really impressed. There is so much detail in this guitar. I have spent 20 minutes staring at the photos and I keep finding interesting and unique design features. Awesome work!
Rick
These users thanked the author Radiohead for the post: Stuart Gort (Sat Apr 26, 2014 7:03 pm)
PostPosted: Sat Apr 26, 2014 8:18 pm
Stunning! I couldn't quite visualise its final look from the drawings. Worth the wait!
These users thanked the author Nick Royle for the post: Stuart Gort (Sat Apr 26, 2014 10:43 pm)
PostPosted: Mon May 05, 2014 8:51 am
State: Oregon
Nice chatting with you at the Marylhurst show, Stuart. You build some fine instruments.
These users thanked the author Jason Rodgers for the post: John Sonksen (Mon May 05, 2014 11:41 am)
PostPosted: Mon May 05, 2014 11:43 am
Last Name: Sonksen
City: PORTLAND
State: Oregon
Zip/Postal Code: 97216-2013
I've got to second Jason's comments Stuart, your guitars are even more impressive in person. Glad you took the time to go over so much of the thought and work you put into them!
PostPosted: Mon May 05, 2014 7:41 pm
First name: Stuart
Last Name: Gort
Thanks for letting me jabber on about them, guys.
It's easy to see how the Maryhurst show could become a habit. Great group of guys attending.
StuMusic
These users thanked the author Stuart Gort for the post: John Sonksen (Mon May 05, 2014 8:44 pm)
