It is currently Mon Aug 04, 2025 4:06 pm
PostPosted: Sat Feb 18, 2006 2:53 am
First name: Larry
Last Name: Hawes
I want to install my Grover tuners today and can find a 11/32" hole size needed and 'press fit' bushings that are a larger diameter but no size specs for the bushings that I can find. Are the bushings meant to be pressed into the smaller, tuner sized holes, or enlarged to a larger, mysterious for now, sized hole?
Larry
EDIT - Oh and I can find the specs from StewMac as tuner size .248" and bushing size .344" but only the tuner sized hole of 11/32" is referenced.LarryH38766.4551967593
Thank You and Best To All
PostPosted: Sat Feb 18, 2006 3:15 am
First name: Larry
Last Name: Hawes
OK - Did I just figure this out? The 11/32" hole IS the bushing size? And the tuner post rotates through the over sized hole?
Larry
PostPosted: Sat Feb 18, 2006 4:37 am
First name: Larry
Last Name: Hawes
Thanks Hesh
cron
