It is currently Sun Sep 14, 2025 5:57 pm
 Post subject: kerf thickness
PostPosted: Tue Dec 16, 2014 9:36 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
What's the thinnest people make their Uke kerfing
Mike McNerney
 Post subject: Re: kerf thickness
PostPosted: Wed Dec 17, 2014 2:01 pm
City: winnipeg
State: manitoba
Country: canada
I just checked my scraps and they are around 0.260" to 0.285".
Note that my sides are 0.070-0.085" and I cut a 1/16" binding ledge.
I hope that this helps.
Bob :ugeek:
PostPosted: Wed Dec 17, 2014 4:39 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I assume you are asking about the thickness of the lining (how much additional glue surface you add to the sides) and not the actual kerf width (how thick the cuts in the linings are). I have only made one uke, a tenor, so take this with a grain of salt. I used my standard lining arrangement which ends up around 0.25" (three laminated strips about 0.08 - 0.085). In retrospect, I feel like I could have gone with just two strips, rather than 3. I suppose you would have to factor in any binding and purfling plans you have. . .
Bryan Bear PMoMC
PostPosted: Wed Dec 17, 2014 6:31 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Thinnest lining I've seen is no lining at all. It really depends how much you plan to cut into it for binding and purfling.
PostPosted: Wed Dec 17, 2014 7:06 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
thanks everyone that helps
Mike McNerney
PostPosted: Wed Dec 17, 2014 8:17 pm
.040"
PostPosted: Fri Dec 26, 2014 10:19 am
First name: Nils
Last Name: Johnson
City: Boston
State: Massachusetts
you can go pretty thin with it. Just make sure you don't go too thin, then cut a binding channel , and have nothing holding your top or back on.
PostPosted: Fri Dec 26, 2014 11:09 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
Thanks to all, & I am not surprised to see a range of thicknesses going down low (.040). I know at least one guitar builder (400+) that goes very low on his tops.
I have settled on .100 which seems to be bending well on the pipe.
I may not even bind these first 2 instruments but if I do, am considering .030 to .050 on the binding, with no purfling.
cheers
Mike McNerney
