It is currently Fri Jun 13, 2025 12:20 am
PostPosted: Sun Mar 08, 2015 12:36 pm
Last Name: cody
City: Lumberton
State: tx
Zip/Postal Code: 77567
Building a tele. First time. Using Fender Texas special pickup. Anyone know router depth for bridge and neck pickup ?
PostPosted: Thu Mar 12, 2015 8:05 am
I was about to ask the same general question, but for a pickguard-less strat.
PostPosted: Thu Mar 12, 2015 10:43 am
First name: Freeman
Last Name: Keller
My Unden plans say 1 inch for the pups for both Tele and Strat, 1-3/8 for the electronic cavity.
These users thanked the author Freeman for the post: dberkowitz (Thu Mar 12, 2015 11:21 am)
PostPosted: Thu Mar 12, 2015 11:02 am
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Strat and Tele style pickups are usually mounted to the pickguard and have springs for vertical adjustment. With that type of arrangement, the depth of the route isn't critical, as long as it's deep enough it's fine.
There are those that believe that mounting the pickups directly to the body is a better approach, and in that case the depth of the route is critical because it sets the distance between the top of the pickup and the strings. That's the way I usually do it, and I always measure the actual pickup to determine the depth of the route.
These users thanked the author Rodger Knox for the post: dberkowitz (Thu Mar 12, 2015 11:22 am)
PostPosted: Thu Mar 12, 2015 12:29 pm
State: AR
Tele neck- @3/4"
Tele bridge- @7/8"
Strat vintage - 5/8"
Strat Contemporary- 3/4"
( my first build, below, was a neck-thru Strat style with no pickguard and I went 3/4" with woodscrews and surgical tubing for mounting the pups and worked out great...also used foam padding to keep them level)
It hangs in my shop...inspiration... even though it's a great player.
PostPosted: Thu Mar 12, 2015 9:05 pm
First name: Freeman
Last Name: Keller
I'm glad you guys chimed in - I was about to build a tele and would have followed these plans. I'll probably start with Sandywood's numbers since I can always make it deeper, but I'll also measure the pups when I get them.
PostPosted: Fri Mar 13, 2015 6:31 am
State: AR
With the Vintage style routes for the Strat the bridge cavity will have a round bottom route @ 1/4" deep x @1/4" wide that goes from the channel that connects all the pup cavities to the control cavity. It's there so there is plenty of room for all 3 pickup wires to run under the bridge pup.
If one is screwing pickups down rather than using the pickguard mount it's always good to make sure one knows where the screw is going. I didn't have that concern with mine because it's a hardtail. I haven't screwed down any pickups with a trem Strat style so I don't know if there are any issues and I'm not around a guitar at the moment.
Same issue with the spring claw screws...it's possible to drill the two mounting holes deep enough to make it into the neck pickup cavity LOL.
PostPosted: Fri Mar 13, 2015 9:20 pm
Last Name: cody
City: Lumberton
State: tx
thanks for the help guys. Got it done. was unsure probably due to reading so much information on line it becomes counter productive.
PostPosted: Fri Mar 13, 2015 9:35 pm
First name: D
Last Name: S
Sandywood wrote:
Tele neck- @3/4"
Tele bridge- @7/8"
Sa-weet! Very nice!
wah
Wah-wah-wah-wah
Wah
cron
