It is currently Sun Sep 14, 2025 1:55 am
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Feb 24, 2015 12:31 pm
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
Good work. I have an old 000-15 with a completely destroyed bass side have to replace. Going to try and do it without removing top and back. Bu may take top off because it has issues already of loose braces and either replace or repair it.
PostPosted: Sat Feb 28, 2015 12:12 am
First name: Allan
Last Name: Bacon
It's too late for this one, but down the road if you "notch" a structural brace try to avoid square corners. Speaking from an aircraft structures background, having radii rather than square corners will provide a better stress path. The notches appear to be approx. 50% through the brace. If you still have the top off, you might try to build a dam on one side and fill the gap with some Gorilla Glue to expand and fill the gap. You want the brace to be able to move but not enough around the notch to propagate a crack.
These users thanked the author fumblefinger for the post: WudWerkr (Sat Feb 28, 2015 3:51 pm)
PostPosted: Sat Feb 28, 2015 3:53 pm
First name: Big
Last Name: Jim
Good point , thank you . You know with a diploma in drafting in commercial construction, you would have figured I would have thought about that. duh
If you are referenceing the utbThats the way Martin did this one.
PostPosted: Sun Mar 01, 2015 1:19 am
First name: Allan
Last Name: Bacon
"uTB" ? Under the bridge? No, I was talking around the square notches. I'm far from the expert here, (you are!) but my gut tells me that the top is going to flex the most in the center, around the sound hole. I'm thinking if you fill the gap in the notch with the expanded poly so the flex is locally minimized, it's less apt to develop the stress cracks in the corners. But not significantly hamper the motion of the top.
BTW, I love the look of the braces you made. Any time you can save a beauty like this, you need to be [clap] [clap] [clap] !!
PostPosted: Sun Mar 01, 2015 10:20 am
First name: Big
Last Name: Jim
Utb. Upper transverse brace by the neck . You are talking about the x brace I gather, thank you for the compliment, but I ordered these braces from a Martin dealer pre-shaped to keep the originality to it as much as possible. So the notching is all.Martin(with the exception of the lower bout brace over the strips) the x brace in the center I do plan on putting a support in there. Thank you for your observations. I always appreciate feed back
PostPosted: Mon Mar 02, 2015 11:51 am
First name: Big
Last Name: Jim
Applying the X brace Cap and covering a couple cracks that fall under a glued spot that I cannot cleat . Used white Denim and Glue soaked .
PostPosted: Mon Mar 02, 2015 12:43 pm
Lookin Gud Wud ;)
These users thanked the author SteveSmith for the post: WudWerkr (Mon Mar 02, 2015 12:47 pm)
PostPosted: Mon Mar 02, 2015 1:04 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Nice clean work, as usual!
Alex
These users thanked the author Alex Kleon for the post: WudWerkr (Mon Mar 02, 2015 1:22 pm)
PostPosted: Tue Mar 03, 2015 9:13 pm
First name: Allan
Last Name: Bacon
The caps are cool! Where did you find white denim?
PostPosted: Tue Mar 03, 2015 9:47 pm
First name: Big
Last Name: Jim
Mom used to work for a jean company , retired now but used to collect bolt ends . Gave a lot to wife.
PostPosted: Wed Mar 04, 2015 10:31 am
Last Name: Killin
Wud,
This is looking great. I have a Silvertone project that I'm about to start that may require a top removal. I've been thinking about what sort of circus acts I'm going to have to preform to fix the cracks properly with F holes. Top removal may be the best choice on that one if I can maintain the body shape.
In the photo above I'm wondering if that cloth patch at the end is going to interfere with the position of the tail block. You are probably good and I only bring it up just in case. Its the kind of thing I'd only realize once I had the glue on and the clamps ready.
PostPosted: Wed Mar 04, 2015 10:33 am
First name: Big
Last Name: Jim
The tail block on this Martin is beveled at all four sides . so the point that meets the top is only 1/4" wide . Good question Though ! [:Y:]
PostPosted: Sat Mar 07, 2015 3:23 pm
First name: Big
Last Name: Jim
Decided to completely refinish the Top . Dont know If I will ever be able to hide those repaired cracks . My do a custom burst since I am planning on keeping this one for myself .
PostPosted: Thu Mar 12, 2015 7:50 pm
First name: Big
Last Name: Jim
Delete these nasty Pictures laughing6-hehe laughing6-hehe
PostPosted: Thu Mar 12, 2015 8:23 pm
Interesting idea but not to my taste. But than again, I'm a traditionalist
PostPosted: Fri Mar 13, 2015 9:36 am
First name: Big
Last Name: Jim
Decided .... Going to strip it back down and work on cracks some more with spruce strips instead of filler ... start again
PostPosted: Fri Mar 13, 2015 11:30 am
First name: Alex
Last Name: Kleon
City: Whitby
Can't say I like it, either, Wud.
Alex
PostPosted: Fri Mar 13, 2015 2:03 pm
First name: Big
Last Name: Jim
The spruce filler took on the color . I am going to take the filler out and use spruce wood and glue it in and scrape level and see where I am at .
PostPosted: Fri Mar 13, 2015 6:26 pm
Oooh that was hideous Jim. Good to see you came to your senses.
Are you going to try the v-groove bit in the router trick now?
PostPosted: Fri Mar 13, 2015 11:33 pm
First name: Allan
Last Name: Bacon
I've actually used ebony "accent" strips over some glued cracks. There again, if you're keeping it, make it whatever you like, forget what anyone else says. If it were me I'd have called the strips "character" and finished it. Showing the cracks you've repaired wouldn't bother me. And if anyone asked, you could always tell them that you did it intentionally. Racing stripes?
PostPosted: Mon Mar 16, 2015 3:07 pm
First name: Big
Last Name: Jim
Spruce Strips in Place . Going to try my hand at Pumice Fill
PostPosted: Mon Mar 16, 2015 7:45 pm
The strips look good Wud
PostPosted: Tue Apr 21, 2015 8:33 am
First name: Big
Last Name: Jim
Getting Closer . The white Binding and black top are gonna rock .
PostPosted: Thu Apr 23, 2015 6:33 pm
First name: Big
Last Name: Jim
Getting Closer
PostPosted: Thu Apr 23, 2015 6:49 pm
Last Name: Killin
That's looking good Wud.
I have a Martin project I've been working on that is right about at this stage. I hope that some day I get the finish right then I can move on to fussing with the next step.
