It is currently Mon Aug 04, 2025 4:54 pm
PostPosted: Sun Feb 26, 2006 9:50 am
Well, bit of a setback today...
I've been working on the fingerboard, and to make a long story short, I
just planed the thing too darn thin! I'm working mostly with hand tools,
and while I usually don't have any trouble face jointing with my Stanley
#6, for some reason I just could *NOT* get a flat face on this fingerboard.
Before I knew it, I had about 1/8" of wood left at one end. I
Oh well, lessons learned. I think I'm just going to buy a pre-dimensioned
and pre-slotted fingerboard for this build. I'll see if I can't salvage this
piece maybe as a mandolin fingerboard. I needed an excuse to start
another mandolin anyway...
PostPosted: Sun Feb 26, 2006 9:51 am
You need a Craig Holden fretboard arching jig !
It works really really well.
PostPosted: Sun Feb 26, 2006 12:04 pm
[QUOTE=Don Williams] You need a Craig Holden fretboard arching jig !
It works really really well.[/QUOTE]
Which would take care of the top of the fretboard, but not the bottom
gluing surface, which still has to be flat!
His is a neat looking tool, though.
PostPosted: Sun Feb 26, 2006 12:44 pm
HI JAY,
I HAVE A BUNCH OF FRETBOARDS. IF YOU WOULD LIKE ONE I CAN SEND ONE TO YOU...FREE.
THEY ARE RADIUSED 16 AND SLOTTED TO 25.4'
LET ME KNOW IF I CAN HELP.
WALTER
PostPosted: Sun Feb 26, 2006 12:50 pm
Walter, I just wanna say it again...YOU ARE THE MAN! Hope you're feeling better!
PostPosted: Sun Feb 26, 2006 12:57 pm
Thanks Walter, I like having my heart warmed!! Very glad to have you back!
PostPosted: Sun Feb 26, 2006 1:16 pm
[QUOTE=WalterK] HI JAY,
ONE TO YOU...FREE.
WALTER [/QUOTE]
Wow, Walter, that's an incredibly generous offer. I'll send you a PM!
Jay
PostPosted: Sun Feb 26, 2006 1:33 pm
Hi again Jay,
I have rosewood and Ebony wood FB's.
Some are 24.9" sacale too!
Let me know what you are using.
Thanks again,
walter
PostPosted: Sun Feb 26, 2006 6:56 pm
For flattening the bottom, there's always the old standby 'piece of sandpaper stuck to a flat surface' trick, if the plane's being annoying...
PostPosted: Sun Feb 26, 2006 10:05 pm
[QUOTE=Mattia Valente] For flattening the bottom, there's always the old standby 'piece of sandpaper stuck to a flat surface' trick, if the plane's being annoying...[/QUOTE]
Mattia, Isn't it true though that you get a better surface by planing?
Oh, and what about the shwoosh of the plane and the cute curley shavings! Boy you change your mind a lot!
Sorry, couldn't resist, Steve
PostPosted: Sun Feb 26, 2006 11:30 pm
[QUOTE=sfbrown] [QUOTE=Mattia Valente] For flattening the bottom, there's always the old standby 'piece of sandpaper stuck to a flat surface' trick, if the plane's being annoying...[/QUOTE]
Sorry, couldn't resist, Steve [/QUOTE]
It is, you do, but sometimes, y'know, if your plane's not sharp enough, or the ebony's being annoying, it's easiest to sand level. And then use a scraper (fluffy shavings!!) to clean up any sanding marks.
PostPosted: Mon Feb 27, 2006 3:27 am
Good point about using the sandpaper and reference plate for flattening a "disobedient" piece of wood. I've got a granite surface plate just perfect for that task.
As to the surface it leaves, it wouldn't be as smooth as a planed surface, but it should be more than sufficient for gluing.
PostPosted: Mon Feb 27, 2006 3:37 am
Jay,
I gotcha beat. On my first, I planed it down to about 3/32 at the sound hole end. Since it was for me and I had already made a ton of mistakes on this guitar. I went ahead and used it. It looks OK except for being thin and I don't think it has affected the sound. By the way, I don't show this guitar to anyone.
PostPosted: Mon Feb 27, 2006 8:44 am
A possible option (when Walter runs out of wood!), would be to make an appropriate neck-long shim of a compatible hardwood, glue it under the fingerboard, and bind that puppy!
