It is currently Sun Sep 14, 2025 10:11 am
PostPosted: Sun May 24, 2015 9:15 pm
First name: Glenn
Last Name: Aycock
City: El Lago
Zip/Postal Code: 77586
Just finished this jig - based on similar designs I've seen around various luth forums. Looks promising but it still needs a few tweaks.
The router itself is questionable, but I didn't want to permanently mount my good PC router on it.
Tomorrow I'm going to put a larger bit on it and add a dust collection port.
PostPosted: Mon May 25, 2015 10:02 am
First name: Glenn
Last Name: Aycock
City: El Lago
Works much better with a 1/2" straight cut bit instead of a 1/4" spiral cutter. The depth keeps slipping. I'm not sure if it's the collet or the base. What a piece of crap.
These users thanked the author Glenn_Aycock for the post: Bri (Tue Jun 02, 2015 9:14 am)
PostPosted: Mon May 25, 2015 4:55 pm
First name: Glenn
Last Name: Aycock
City: El Lago
After replacing the wing nut with a lock nut and tightening everything up, it works much better.
Still not 100% - there's a bit of flex somewhere that throws the cuts off. I may try a round nose bit.
PostPosted: Tue May 26, 2015 12:15 pm
First name: Glenn
Last Name: Aycock
City: El Lago
Got it dialed in now - with the straight cutter. Round nose bit not recommended.
Turned out to be an engineering problem. The upright was flexing due to my downward pressure as I swung the router. I reinforced it and added a handle close to the side to minimize flexing. It works reasonably well now.
I can't really say it was economical, but I can make blocks in any length and radius up to 22".
