It is currently Mon Sep 15, 2025 6:11 pm
PostPosted: Thu May 21, 2015 4:30 pm
I'm starting this thread so others can learn from our mistakes. Feel free to post your own "Note To Self " moments.
So I'll start this off with my latest DOH! moment;
Note to self - Dont try to cut a scarf joint with a fret saw. Looks like I'll be spending another $40.00 at Stew-Mac.
PostPosted: Thu May 28, 2015 2:28 am
Last Name: Kincheloe
These are good for scarf cutting: http://www.amazon.com/Tajima-JPR-265-Fine-Cut-Elastomer-Non-Slip/dp/B0042BAH6K/ref=sr_1_3?ie=UTF8&qid=1432797888&sr=8-3&keywords=tajima+saw+265
Note to self: Yes, putting tape on the fingerboard before leveling frets is a pain, but it's not as much of a pain as trying to get the fine metal dust out of the wood if you skip it.
PostPosted: Sun May 31, 2015 9:33 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
So, what happened?
I've got so many notes to self in my
brain that there's no room for anything else!!!
A
PostPosted: Fri Jun 05, 2015 6:02 pm
@ alan stassforth,
Sorry for late reply. I got disgusted with myself and threw the project on the shelf.
I warped the fret saw. oops_sign
I Tried to cut through a 3" x 3/4" neck of maple and bubinga. I generated too much heat for the flimsy saw blade and it's warped. It's junk.
I'm going to try DennisK's mention for my next one (thanks for that DK), and I have a new fret saw on order.
Maybe I should have titled this thread "Never Do This When Building Guitars".
PostPosted: Wed Jun 10, 2015 8:40 pm
First name: Jim
Last Name: Outman
City: LaGrange
State: GA
Zip/Postal Code: 30240
Note to self: Make sure your templates are attached well before you pick up that router! Also make sure the bit is tight in the chuck. beehive
A handy tool I got recently is a Japanese pull saw from Home Depot. Cuts surprisingly well and with the flexible blade it will go in places I won't trust a power tool to go. Even used it for finishing off the trim on my workshop recently.
PostPosted: Wed Jun 10, 2015 9:00 pm
First name: D
Last Name: S
I almost bought one of them. I read the kerf is just right for frets. You need to add a stiffener to use as a fret saw.
wah
Wah-wah-wah-wah
Wah
PostPosted: Wed Jun 10, 2015 9:04 pm
First name: D
Last Name: S
On my current build, I only used a bandsaw for the rough cuts.
I figured I'd do this one using only hand cutting tools.
I used my router for the truss rod slot. I watched in horror as the bit rose up through the back of the neck.
Note to self: throw that 30-year old router into the pond.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun Jun 14, 2015 12:39 pm
First name: alan
City: Santa Rosa
State: ca
Those Japanese pull saws are great.
I have one in me work truck.
FWIW, I use a sharp backsaw.
About 3.5" tall, and 14" long.
I go real slow, and really watch the line!
A
