It is currently Mon Aug 04, 2025 4:45 pm
PostPosted: Fri Mar 03, 2006 11:27 am
As everyone knows the name originally was the Chairity Guitar. That was changed when it became a Gift Guitar and is now the OLF Guitar Project #2. I have no clue as to whether donors wish to continue to participate?
Michael, we'll just have to trek through these gleaned posts to determine viability. This might just require PM'ing each person and waiting for a response. Here is the gleaned list from original posts.
Body
Dave Rector, abalone rosette
Bob Cefalu, mahogany back and sides, bindings, headstock overlay
Lance Kragenbrink, bend sides and install tailblock, sent linings
Michael Propsom sent French purflings with the replaced abalone
Paul Woolson, furnished back braces, his cool aspen reverse kerf two part linings, side splints, constructed back, glued in headblock, linings and radiused both the back and top. Paul installed the back and may also have furnished the neckblock with fb extension.
Bruce Dickey, furnished a AAA Sitka Top from BC, Adirondack red spruce bracing, glued braces with hot hide glue, installed red abalone rosette with french purfling. Will complete top and install on rimset.
Brock Poling, install purfling and binding
Neck
John Mayes, Slot and radius a fretboard, install side dots
Jerry Hossom, furnish truss rod or cash
Paul Davis, laminate neck
John How, Construct and carve neck, install truss rod and fretboard.
Hank Mauel, Fret the neck and dress fret ends
Craig Lavin, fretboard and headstock inlay
Hardware
Brock Poling, furnish bridge pins and end pin
Wade Sylvester, furnish fretboard markers
Walter Kiralla, Schaller tuners
Dennis Leahy, a duplicate offer, ebony fretboard
George Armstrong, Access Stage 5 Guitar Case or Gotoh 510 gold and black tuners
Don Atwood, K and K Pure Western Pickup System
John Hall, donated an OLF SJ Mold, He asked that it be auctioned off and use the proceeds for expenses of the OLF #2 guitar build as we see fit.
Finishing
Michael Payne, French polish the guitar and install label
CrazymanMichael, Final setup, nut and saddle
Steve Tool, fabricate a bridge
Shipping Cash
Mike Tobey
One donor is unnamed.
Hesh Breakstone
Scott Thompson
Unspecified offers
John Hall, Blues Creek Guitars, donated a mold of the SJ
The SJ mold was purchased by Todd Rose supporting our effort to make this build and pay shipping.
Roy O., contribute something
Frank C., donate something
Let me know if any of this is not accurate and I'll correct it. PM me.Bruce Dickey38784.3718402778
PostPosted: Fri Mar 03, 2006 12:59 pm
A couple questions?
1) Ebony bridge? I only ask because I am supplying the pins. Any preference on the type of pins? I have lots of different types of gurian wood pins and a few sets of bone.
2) I presume you don't need an end pin since it has a pick up.
3) What is the back and side wood (I can't really tell from the pics)?
4) Any preference regarding the species of binding we use? I don't see that spec'd.
PostPosted: Fri Mar 03, 2006 1:19 pm
Hi Brock, those notations were abstracted out of the Charity guitar posts from months ago. End Pin, you are right, unless of course Don already gave away that K and K?
Ebony pins on ebony bridge looks good. Really it's a choice thing, your choice.
Binding specs, hmmmmm, Michael might direct us there because I don't have that information. I was told by someone that it would have French style purfs which are bwb with the black both larger than the white lines. I suppose the degree of difficulty on the purfling top or sides would be up to you as well.
Back and side wood appears to be figured mahogany.
Zootman Bob was noted as supplier on the binding, you might ask him?
Great, this is exactly the type of conversation we need.
PostPosted: Fri Mar 03, 2006 1:55 pm
Ok. When I see it I will figure it out.
But here is what I am thinking at the moment.
Binding = BRW or Cocobolo (depending on color)
End graft = Chevron cut and joined to match binding
Top purflings = mahog-o-lam (or possibly snake-o-lam)
Side purfs = fine line bwb mitered around the end graft.
How does that sound?
PostPosted: Fri Mar 03, 2006 2:14 pm
First name: Craig
Last Name: Lavin
City: Sunrise
State: Fl
Zip/Postal Code: 33323
board are ebony.
Were they sent out yet?
Craig
www.handcraftinlay.com
PostPosted: Fri Mar 03, 2006 3:47 pm
Stop the presses... sounds like the fb and headstock are bound in bloodwood. So the body will do the same...
PostPosted: Fri Mar 03, 2006 3:50 pm
[QUOTE=Bruce Dickey] Hi Brock, those notations were abstracted out of the Charity guitar posts from months ago. End Pin, you are right, unless of course Don already gave away that K and K?
Nope, I've still got one put back for this guitar.Don A38779.9938657407
PostPosted: Fri Mar 03, 2006 4:29 pm
Cool. Well if we are going with bloodwood binding, I think the original purf scheme sounds great.
PostPosted: Sat Mar 04, 2006 2:21 am
Where do these French Purflings come from? I looked at LMI and they seem to have all layers the same.
Michael P., where do we get these?
PostPosted: Sat Mar 04, 2006 7:55 pm
[QUOTE=clavin] board are ebony.
Were they sent out yet? Craig [/QUOTE]
Craig, do you want to inlay before attaching the headplate and fingerboard this time? We could get it to you quicker that way? What do you think? Michael P is that possible?
