It is currently Sat Sep 13, 2025 9:13 pm
PostPosted: Mon Feb 22, 2016 6:24 am
Nothing that special, but knocked this up to fit a plastic binding strip at the tail because it has to be pretty nigh perfect for depth control, and hand tools were a challenge with the wood involved.
Pretty self explanatory, rectangular 1/2" birch ply halves connected by 4" x 1.5" of 1/2"" birch ply strips (to clear bolt slots) glued underneath at front and back.
2 pieces of 2 1/2" high x 2" wide pine bars underneath to grip guitar (cut out to clear the 1/2" birch ply connecting strips), with 2 1/2" square x 1/8" cork pads at the gripping ends underneath.
Held in place with cam clamps.
The slots are 1 mm wider than the 1/4" coach bolts diameter to allow "floating" adjustment for lining up, uses a 20 mm guide bush in the router.
Line up was set with an acrylic strip 20mm wide with centre line scribed on it, checked with a 1/4" pointed rod in the router, cut with 6 mm 2 flute straight bit and a fine depth adjustment in small steps.
I also use a similar set-up for routing an oval soundport, using a 6 mm mdf plate with an oval cut in it, and can vary guide bush sizes to change hole size (cut with a spiral downcut bit)
These users thanked the author Colin North for the post: Joe Beaver (Thu Mar 23, 2017 1:13 pm)
PostPosted: Mon Feb 22, 2016 7:32 am
Nice Colin, great jig! This is way easier than what I used to do free hand with an engineer's scale as a guide.
Thanks for posting this!
PostPosted: Mon Feb 22, 2016 9:48 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Thanks for sharing, Colin! I always have lots of scrap ply kicking around, so I'll be making one soon!
Alex
PostPosted: Mon Feb 22, 2016 10:42 am
Some more pics, better than a description - End and side views, note the amended dimensions in first post.
Excuse the CA everywhere, I'll maybe pretty it up and nicely round the corners later.
Worked fine
PostPosted: Mon Feb 22, 2016 10:58 am
Yes, used to do it the same way, but last guitar I made with this wood was pretty tough to cut and chisel without chipping out and needed some filling, so wanted to avoid that.
PostPosted: Mon Feb 22, 2016 10:32 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Simple and eloquent - the best kind of jig. Why not permantely fasten one of the 2 X 's to ensure that the cut is square to the body?
Ed
These users thanked the author Ruby50 for the post: Colin North (Tue Feb 23, 2016 3:09 am)
PostPosted: Tue Feb 23, 2016 3:24 am
Hi Ed. You could if you want.
But with the 1/8" cork to prevent marking the guitar, it will compress (it also takes up some of the curve of top and back), any difference in clamping pressure side to side, the actual areas of contact of the cork on each side , or compressability of the cork itself will misalign it.
Also this flexibility allows for any slight variation you may actually want to make in the end strip alignment, due to top/back plates being slightly misaligned, lining up with centre strips in the back for example, or a noticeable pattern in the top plate.
This variation may be less noticeable than a slight misalignment of center strip and tail end strip.
PostPosted: Wed Feb 24, 2016 5:48 am
Last Name: Minch
City: Chestertown
I get it - good call
Ed
