It is currently Sat Nov 30, 2024 5:53 pm
PostPosted: Tue Mar 15, 2016 1:19 pm
First name: Frank
City: Saranac Lake
I cut it a little too thin. I'm using grover short post tuners. Will this still hold up or should I add a thin piece to add thickness?
Build it cause then you know it's Made in the USA or **insert your country**
PostPosted: Tue Mar 15, 2016 4:33 pm
Last Name: Reed
City: Stowmarket
State: Suffolk
Zip/Postal Code: IP14 2EX
Country: UK
Structurally you're fine. So if the tuners fit, go for it.
If you don't like the look, or need more thickness for the tuners, add a headplate.
PostPosted: Sun Mar 27, 2016 10:49 pm
First name: David
City: Napa
Zip/Postal Code: 94558
A headstock overlay is always an easy fix.
PostPosted: Sun Mar 27, 2016 11:07 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
Or if you are still too thin a back strap veneer! That is what I had to do when I slipped in a drum sander.
Users browsing this forum: No registered users and 49 guests
