It is currently Wed Nov 27, 2024 9:48 pm
 Post subject: Uke Mortise and Tenon
PostPosted: Wed Apr 06, 2016 12:47 pm
First name: Brad
Last Name: Combs
Hello,
I'm in the process of building a tenor uke based on the plan from Georgia Luthier Supply here: http://ultimate-guitar-online.ultimate- ... cts_id=213
Regarding the mortise and tenon, I have built the neck angle jig that Robert O'Brien covers here for building guitars: https://www.youtube.com/watch?v=nJLfkh3GgFU
I'm using the templates from LMI here: http://www.lmii.com/products/tools-serv ... -templates
Questions:
1) I'm thinking I can make a template for the tenon side that would work for the size of the tenon called out in the plan. I also think I can just use a larger guide bushing on the guitar mortise template and have it match or be close to my custom tenon template. Do you folks use this type if jig for uke building or is there a more simple way?
2) Do I pretty much follow the same method as I use for guitar to set the neck angle on the uke?
Thanks!
Brad
PostPosted: Wed Apr 06, 2016 2:37 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I use a single bolt butt joint on a ukulele. Also my ukulele have no angle for the neck, makes life easyas I make a flat top. Your plan for the mortise and tenon should be fine.
The saddle height on my tenors is 10 or 11 mm. This about 4 mm lower than my SS guitars. Also the action is a little higher on a nylon string ukulele. For these reasons I do not need the back neck angle.
Some use a forward angle like a classical guitar. I do not but my fret board is 2mm thinner than a typical classical fret board. All in all I get the right saddle height and the right action with no angle.
These users thanked the author johnparchem for the post (total 3): pkdz (Wed Jun 08, 2016 3:58 pm) • edstrummer (Wed Apr 06, 2016 5:22 pm) • bcombs510 (Wed Apr 06, 2016 2:58 pm)
PostPosted: Wed Apr 06, 2016 4:15 pm
I also use an sbbj and do my angle pretty much like a guitar.
Sent from my SM-T350 using Tapatalk
These users thanked the author Pmaj7 for the post (total 2): pkdz (Wed Jun 08, 2016 3:58 pm) • bcombs510 (Thu Apr 07, 2016 8:56 pm)
PostPosted: Wed Apr 06, 2016 7:32 pm
First name: Brad
Last Name: Combs
What do you guys like to use for the bolt? I've seen the type that is wood screw on one end and threaded rod on the other. Also the wood insert type that is wood threads on the outside and a threaded receiver on the inside. Something like that?
PostPosted: Thu Apr 07, 2016 1:50 am
First name: Aaron
I had my templates custom made for me, using a 1/2" pattern bit on a smaller version of Robbie's jig. Its described in detail in the Lounge on the Underground in my "Out of the box" thread.
Even with the 1/2" tenon, I use two 1/4x20 threaded inserts a la LMI.
These users thanked the author Aaron O for the post (total 2): pkdz (Wed Jun 08, 2016 3:58 pm) • bcombs510 (Thu Apr 07, 2016 6:26 am)
PostPosted: Thu Apr 07, 2016 12:19 pm
City: winnipeg
State: manitoba
Country: canada
I have used a dress bolt (home despot) to a tee-nut inside with a butt-joint and it works for me.
I pull emery tape through the joint to improve the fit.
Bob :ugeek:
These users thanked the author unkabob for the post: bcombs510 (Thu Apr 07, 2016 1:34 pm)
PostPosted: Thu Apr 07, 2016 8:10 pm
Lmi style or furniture bolt.
These users thanked the author Pmaj7 for the post: bcombs510 (Thu Apr 07, 2016 8:55 pm)
Users browsing this forum: No registered users and 87 guests
