It is currently Mon Sep 15, 2025 4:29 pm
PostPosted: Sun Apr 10, 2016 7:17 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
This repair was - from what I have seen - pretty routine. Some missing wood and lacquer, but good long grain gluing area, and the owner was kind enough to avoid causing too much additional damage due to handling or curiosity about whether the two parts would rejoin. After a tense session using the surgical loups, vessel clamps, and various dental picks to remove each offending splinter, we got this one back together with hot hide and our neck splint fixture.
We see a fair number of repaired and re-broken Gibson head stocks, as well as amateur neck repair attempts, so the last thing the boss wanted to see was the usual shaded or 'sunbursted' shortcut repair. I ended up doing the fine point and airbrush work and most of the top lacquer coats...with extensive 'over the shoulder' surveillance, of course. gaah
The toughest part of these sort of repairs seems to be gaining and maintaining alignment of the fragments of the peg head with neck shaft. I found some useful posts on fixtures and different approaches to disguising the damage on several other web sites, as well as in the archives here, but ended up using the existing shop fixture for the job.
If you look carefully, you can see why the boss made me strip the strings, tuners, and truss rod cover to retouch the transition area of the neck and to rebuff the peg head near the upper truss rod cover screw. Came out better, but the customer was at that point 20 minutes out from pickup, so no 'final-final' shots. :oops:
Thanks, OLF!
- Beth Brower
PostPosted: Sun Apr 10, 2016 8:01 am
Very well done!
PostPosted: Sun Apr 10, 2016 8:47 am
Broken neck? What broken neck?
:D
PostPosted: Sun Apr 10, 2016 11:43 am
First name: Jan-Alexis
Last Name: Tremblay
City: Montreal
Clean!
PostPosted: Mon Apr 11, 2016 1:24 pm
Last Name: Lee
City: Albany Creek
State: QLD
Zip/Postal Code: 4035
Very neat job
PostPosted: Mon Apr 11, 2016 2:32 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
That's better than new!
Alex
PostPosted: Tue Apr 12, 2016 7:06 am
Excellent repair. Any chance you can share a photo of your shop fixture? I have an acoustic with a broken headstock in the shop that eventually needs to be repaired so it can go to a good home.
PostPosted: Tue Apr 12, 2016 1:33 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
I'll see if I can get a shot or two...those are not yet on the Google Drive! A richly deserved weekend off coming up, so it may be a few days. From what I recall, it is based loosely on David Collin's fixture, which is in this thread on Frets.net (yes...I lurk in many, many forums... wow7-eyes)
http://fretsnet.ning.com/forum/topics/headstock-repair-jig-that-i-would-love-to-get-the-plans-for?id=2177249%3ATopic%3A118560&page=1#comments
- Beth Brower
PostPosted: Tue Apr 12, 2016 6:36 pm
That's it Woodie. Thanks. I'll be headed up to David's shop at the end of this month so I should be able to see it in person.
