It is currently Sun Sep 14, 2025 9:58 pm
PostPosted: Tue Apr 12, 2016 9:52 am
First name: Craig
Last Name: Gordon
Zip/Postal Code: 14216
I have been tasked with repairing a re-broken headstock on a Les Paul that had been previously badly glued with what appears to be 5 minute epoxy. The joint is now badly contaminated with the cured adhesive. It is soft enough to pick at but difficult to get out of the fibers.
What is the best way to clean this and then reglue it?
It is a very bad break.
Craig
PostPosted: Tue Apr 12, 2016 11:20 am
Sit down with a sharp Exacto knife and a toothbrush. Have fun, and thank your lucky stars it wasn't hot glue.
PostPosted: Tue Apr 12, 2016 12:42 pm
First name: Dan
Last Name: Savage
City: Trabuco Canyon
Zip/Postal Code: 92679
You might also try using a heat gun to soften the epoxy then use a stiff-bristle brush to scrub the glue out of the break.
You'll never get the epoxy that's soaked into the wood out of the wood fibers. On the bright side, if it really was 5-minute epoxy, it won't have had time to soak very deeply into the wood before curing so you may be able to get down to bare wood as the glue had only a mechanical bond to the surface.
PostPosted: Wed Apr 13, 2016 7:26 am
First name: Craig
Last Name: Gordon
It certainly seems to have the texture of 5 min epoxy, a bit soft. I'll clean it out as meticulously as I can, reglue and apply a backstrap overlay.
