It is currently Tue Aug 05, 2025 1:23 pm
PostPosted: Wed Mar 08, 2006 6:28 am
First name: Nelson
Last Name: Palen
I discovered last evening that a 1/2 oz. size TicTac box works pretty good. It's about the right size for a quarter sheet of sandpaper that has been quartered again. (2 1/4" x 2 3/4")
The plastic box has some flexibility but not too much. Fill it with your favorite wet sanding solution for a "ready reservoir".   Throw in a few BB's for some sound effects and you can sand in time with your favorite music.
I'll bet you guys have come up with some strange devices to use as sanding pads also?
Nelson
npalen38784.6858333333
PostPosted: Wed Mar 08, 2006 6:57 am
New flip flops run through the bandsaw. Soft, flexible, cheap. I think that idea came from Frank of Frets.com?
PostPosted: Wed Mar 08, 2006 7:29 am
My large rubber erasers from the Office Depot are one of my favorite sanding blocks. They'll even sand around the curves after the sides have been glued up.
PostPosted: Wed Mar 08, 2006 7:35 am
While I was trying to stuff my fingers down inside the ramps of a slot head to sand them (without changing the shape) I was thinking it would be a great idea to make erasers with sanding grits embedded into them.
They could be shaped to fit into those spots but still be abrasive.
PostPosted: Wed Mar 08, 2006 7:37 am
rough sanding I use the back of my neck when Diane is yelling at me perfect 80 grit
PostPosted: Thu Mar 09, 2006 5:06 am
empty toilet paper rolls for the waist and inner curves on neck heel and headstock
PostPosted: Thu Mar 09, 2006 5:28 am
Last Name: Beaver
City: Lake Forest
What's next? Tampons to polish the sound hole? Will it never end?
Joe Beaver
Maker of Sawdust
PostPosted: Thu Mar 09, 2006 6:50 am
We have wide roll plotters at work. The paper is wound on plastic tubular cores that are great for sanding 'blocks'.
I use rubber cement to retain the sandpapers. You can get several pads from one tube.
Another office item I have used is empty dry erase marker tubes from the conference room wastebaskets.
PostPosted: Thu Mar 09, 2006 7:27 am
I dont want to scare you but depending on what you use this round form to sand, You might want to put a straight edge to the tube be for using. Being in a engineering department myself, we also have these tubes, and I have yet to find one that did not have at leat a 16" devatin in roundness and dia. over a 12" length
This can cause problems if used to sand sides and such. especially if done before routing binding channels and using pilot bearings.
PostPosted: Thu Mar 09, 2006 7:33 am
I was warching a thing on TV a while back and some one was tring to sand mouldings, he rubbed a piece of pumice stone into the shape of the moulding and used that, maybe that could be useful in the headstock scenario, mind you where you get pumice stone I haven't a clue
PostPosted: Thu Mar 09, 2006 7:52 am
I use erasers a lot, but I love the flip-flop idea. Off to the dollar store!
PostPosted: Thu Mar 09, 2006 7:53 am
most hardware stores have it in there abrasive departments. use to clean grills. It, itself is abrasive
PostPosted: Thu Mar 09, 2006 7:55 am
First name: Nelson
Last Name: Palen
Back in my day they called them thongs rather than flip-flops. I suppose that is no longer "politically correct", however.
Users browsing this forum: Bing [Bot] and 39 guests
