It is currently Sat Sep 13, 2025 10:26 am
PostPosted: Thu Mar 09, 2006 11:01 pm
Planning a redwood top for a future build and reviewed lots of OLF archive discussions but did not find any comments on bracing.
What bracing materials have you used with redwood? I was thinking Sitka ?
PostPosted: Thu Mar 09, 2006 11:04 pm
Also wondering about thickness compared to Spruce. Thinner or thicker? I see posts that suggested .11 but then tought I heard thicker is better and suggesting .12
I guess this is dependendent on stiffness and tap.
Any difference in bracing? Saw Zootman post that suggested possible soundhole reinforcement.
I am planning a OM model with standnard bracing including 2 lower trebble braces
PostPosted: Thu Mar 09, 2006 11:42 pm
Rich, I have only built with the LS type redwood which is very stiff. I used addy brace stock, and IIFC the tops were around .110 or so. That said, I really don't measure for thickness as much as feel for flex when im thinning them on the sander. Then once again, after its braced and joined to the sides I perimeter sand until I reach a certain feel or flexibility at the bridge location. I'm not sure where everything ends up, I only care what if feels like when its all said and done.
I also use Brazilian bridge patches and am pleased with the sound.
LanceK38786.3237384259
PostPosted: Fri Mar 10, 2006 2:57 am
I know of a builder who regularly builds with redwood who keeps it a lot thicker, more close to .150 for final thickness. I guess it depends on how it flexes and sounds as you tap it and flex while thinning. If it's a floppier piece of wood, you want to go thicker than if you had a really stiff piece. I have a OO going right now with a redwood top, addy braces, and a brw bridge patch. The redwood is reasonably stiff, but not quite as stiff as an LS top. I think it has good potential. We'll see.
I also have some really stiff and super-light redwood brace stock which I might try on another redwood guitar. I like the thought of using braces that are really stiff and super-light. Don Williams38786.4580671296
PostPosted: Fri Mar 10, 2006 5:36 am
I think it's best to think of it as being a wood that should be thicker. Like Lance, use your feel and experience in the end but most of the time for me it has seemed like it wanted to be a bit thicker than I would use Sitka. Redwood can have a whole lot of variation from one batch to another so you really have to choose it carefully.
And can someone please tell me- what is "LS" type redood? Sorry, I don't know that one.
Mark Swanson
Swanson Guitars
PostPosted: Fri Mar 10, 2006 5:42 am
I am assuming LS is lutz spruce???
Woops
the LS was a type of redwood????azimmer138786.5716319444
PostPosted: Fri Mar 10, 2006 5:49 am
I just started the first of the two curly redwood tops I got from BobC. before bracing I ended up at .140 going by flex. If after bracing it needs more I will thin the appropriate areas during voicing.
PostPosted: Fri Mar 10, 2006 5:54 am
[QUOTE=Mark Swanson] I think it's best to think of it as being a wood that should be thicker. Like Lance, use your feel and experience in the end but most of the time for me it has seemed like it wanted to be a bit thicker than I would use Sitka. Redwood can have a whole lot of variation from one batch to another so you really have to choose it carefully.
And can someone please tell me- what is "LS" type redood? Sorry, I don't know that one. [/QUOTE]
LS is from the Lucky Strike log that Craig Carter was cutting up and selling in the 90's. It is hard to lay hands on, but it is very stiff and the color is dark and very even.
Lance has used it.
You have to pay a king's ransom for it if you can even find someone to sell it to you.
Great feedback guys, thanks.
PostPosted: Fri Mar 10, 2006 7:12 am
[QUOTE=Brock Poling]LS is from the Lucky Strike log...
Lance has used it.
The good thing is that there is other redwood out there comparable to it in stiffness, taptone, and color.
The LS is certainly wonderful wood, but the mystique it has gained as a result of naming the logs etc. perhaps has artificially inflated its reputation. I have handled and tapped some LS, and it really is fantastic. I have also handled some that looks and feels and rings just like it, that came from other sources.
I personally have bunches...but wouldn't (and couldn't) sell it for the amounts I've heard that some sell LS for. I heard of one person asking $175 a top for some.
PostPosted: Thu Mar 16, 2006 2:17 pm
Hi all-- I'm not really a luthier, more of a player. But, I would like to comment. I own a guitar Lance made from the "LS" log-- the SJ style shown on his website and in other places. It's rosewood back and sides with the LS Redwood top, simple rosette, and new headstock. Without question, it is an instrument whose sound is as unique as it is beautiful. I can safely describe it as a "lively" guitar-- the notes "jump" out of it with a "throaty" tone very reminiscent of a certain 1935 D-28 that I spent a few minutes with once.
PostPosted: Thu Mar 16, 2006 2:23 pm
Hi John! What a pleasant surprise to see you here!
