It is currently Wed Aug 06, 2025 12:17 am
PostPosted: Fri Mar 17, 2006 5:25 pm
Hi, I bought a scraper and barnisher from Stew-Mac, when you put the hook on the end of the scraper can you actually see it? If you can then I must be doing something wrong or I need my glasses checked. Please tell me what I'm doing wrong, thanks, Red
PostPosted: Fri Mar 17, 2006 5:47 pm
First name: Rich
Last Name: Barbera
City: Bay Area
I'm not so sure if I can see it either, my eyes are slowly slippin' away. I did have this stored away on my computer for reference. I hope it can be of some help?
http://www.brendlers.net/oldtools/scraping/scraper.htm#EdgeP reparation
PostPosted: Fri Mar 17, 2006 6:04 pm
First name: Scott
Last Name: Thompson
The hook is miroscopic, but you can feel it. You'll know it is their because you'll get shavings instead of sawdust.
Scott Thompson
Port Townsend,WA
-Billy Bragg
PostPosted: Fri Mar 17, 2006 11:39 pm
You should be able to catch your nail on the hook if you run your finger along the scraper.
Cheers Martin
PostPosted: Fri Mar 17, 2006 11:55 pm
VERY gentlty, if you run it along the length-if you get a great hook drawn,it's like a razor. I gently run the pad of my thumb across it,checking along the length,
PostPosted: Sat Mar 18, 2006 4:49 am
I second the comment on Boggs. Actually, if anyone gets a chance to take a
class from Brian (I've taken two) I HIGHLY recommend it. The guy has
amazing knowledge of most things related to woodworking. How does this
relate to guitars? Well, I always play while sitting in the chair I made in
Brian's class!
PostPosted: Sat Mar 18, 2006 1:40 pm
JUST BEAT IT WITH A HAMMER...............NOT REALLY DAD
PostPosted: Sat Mar 18, 2006 1:51 pm
Hi Matt and welcome to the OLF!
PostPosted: Sat Mar 18, 2006 3:25 pm
Hi, Red
I've got the burnisher from StewMac. It works really well, but it took me a few tries to get a good hook. After you draw out the burr you have to increase the angle quite a bit to make the hook. Once I found the right angle it became easy to get a good hook.
PostPosted: Sun Mar 19, 2006 10:17 am
Hey, that burnisher looks like a knife steel(you know for straighting an edge). Can you use one of those???
