It is currently Sat Sep 13, 2025 11:08 pm
 Post subject: Starting up the ES-335
PostPosted: Mon Apr 23, 2018 11:29 pm
First name: David
City: Napa
Zip/Postal Code: 94558
1958 ES-335 Dot Neck replica. Starting ups he rims and top.
PostPosted: Tue Apr 24, 2018 9:51 am
First name: D
Last Name: S
Looking great David!
wah
Wah-wah-wah-wah
Wah
PostPosted: Tue Apr 24, 2018 10:23 am
City: Escondido
Zip/Postal Code: 92029
Why the separate tail block from the center block? I’ve seen that before and never understood it.
PostPosted: Tue Apr 24, 2018 11:02 am
First name: David
City: Napa
Because I'm doing a period correct 1958 dot neck. This is how Gibson did it back then. It does make getting the center black in a lot easier as it really needs to be clamped in and snug at the Mickey Mouse ears.
PostPosted: Tue Apr 24, 2018 11:10 am
First name: Freeman
Last Name: Keller
Brings back memories.....
PostPosted: Tue Apr 24, 2018 12:22 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Nice. Are those laminated sides? They look really thick to bend
PostPosted: Tue Apr 24, 2018 12:48 pm
First name: David
City: Napa
Yes the sides are 3 laminated veneers.
PostPosted: Tue Apr 24, 2018 12:51 pm
First name: David
City: Napa
Tops on and getting ready to box her up. After reading about what a nightmare it is to wire these up. I'm tempted to tape in a wired up harness. with pull strings.
PostPosted: Tue Apr 24, 2018 8:56 pm
First name: Freeman
Last Name: Keller
That is exactly what I did.
Its still a hassle to fish them into their holes but at least you don't have to pull everything thru the f-holes. FWIW, I also put some low resistance terminal strips in the pickup sockets so I didn't have to fish pickup wire thru to the pots. It will make it much easier if we ever need to change pups (you can barely see them in the bridge p/u cavity in the bottom picture)
cron
