It is currently Sun Jul 27, 2025 11:32 am
 Post subject: CA for Drop filling...
PostPosted: Sun Aug 26, 2018 12:53 pm
Last Name: Sollod
I have had limited success with drop filling "holes" or voids in the finish around the rosette or otherwise using the same finish material, in this case EM6000. I find that it shrinks back and I have to do it over and over. So, I'm wondering if I could try using CA for drop filling. Based on what I've read here on the OLF, CA should work well for this...(if I've understood this correctly).
If I could expect that CA would blend in to my top coat and be "invisible" I would up for trying it... My strategy would be to apply medium CA and then scrape it even to the top coat with a razor blade. Then do an overall light sanding with 400 grit as I usually do between sessions, before following with additional top coats.
Does this sound reasonable? Should I use medium or thin? Any recommendations or suggestions are welcome.
Here are a couple I'm working on...
www.swiftcreekguitars.com
PostPosted: Sun Aug 26, 2018 1:15 pm
Last Name: Colbert
City: Anacortes
That’s exactly what I’ve been doing. I prefer the thin followed by accelerator. A pipette is kind of a must unless you love extra sanding. I also use a rubber block behind the 400 to make sure the fill ends up nice and flat.
Best, M
PostPosted: Sun Aug 26, 2018 1:32 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I do this as well, totally no issue around sound holes and the like. On my last few guitars, I took extraordinary care to do the drop fills before my final day of spraying. I level EM6000 the day after I spray my first sets of coats. The leveling tends to highlight the voids. I drop fill and level with CA as described. Then there is no issue as CA is covered with the final coats.
PostPosted: Sun Aug 26, 2018 5:08 pm
I do it for repairs, but I do not recommend it for new finishes. It doesn't necessarily burn in. And sometimes it can have a different optical effect. Also, there is the possibility of fuming surrounding finish or air inclusions.
PostPosted: Sun Aug 26, 2018 5:12 pm
I would avoid using accelerator. It can boil thicker fills and make the CA look white.
PostPosted: Sun Aug 26, 2018 8:04 pm
Last Name: Sollod
Barry,
You said, “I do it for repairs, but I do not recommend it for new finishes. It doesn't necessarily burn in. And sometimes it can have a different optical effect. Also, there is the possibility of fuming surrounding finish or air inclusions.”
This is the kind of thing I was concerned about, but it appears that John and Michael have used CA successfully during initial finishing. I would agree that I would be hesitant to use accelerator...
So, I'm left in a quandary. Does anyone else have any experience with using CA for drop filling during initial finishing?
PostPosted: Sun Aug 26, 2018 9:09 pm
Last Name: Colbert
City: Anacortes
sdsollod wrote:
Barry,
I find that the ca won’t go exothermic if you only mist the surface with the accelerator. If you hit it hard with the accelerator it will definitely cause a problem. I’ve never tried this with anything other than EM6000
PostPosted: Mon Aug 27, 2018 5:47 am
you need to check out Glu Boost
CA will show in a few months
PostPosted: Mon Aug 27, 2018 5:51 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
+1 Glu Boost fill n finish and accelerator. Its made for this kind of work and the accelerator won't cause blushing or other problems.
It will probably be alright.
PostPosted: Mon Aug 27, 2018 7:06 am
Yep
PostPosted: Mon Aug 27, 2018 7:38 am
Last Name: Sollod
Do I even need to use Glu Boost? Can't I just give the CA time? It's not like I'm in a hurry...
PostPosted: Mon Aug 27, 2018 7:42 am
Last Name: Sollod
Okay, I got it. This must be the stuff...
https://www.amazon.com/Fill-Finish-Pore ... B01I7AIRMM
PostPosted: Mon Aug 27, 2018 9:19 am
Last Name: Colbert
City: Anacortes
I hadn’t noticed the ca showing over time. I did just order the Gluboost lineup. About time I gave it a try.
PostPosted: Mon Aug 27, 2018 10:20 am
I have not seen CA show up in time either but it might depend on the finish. If you don't polish and sand it back dead level then it will create a lense effect. I don't use accelerator either, I've had bad experience with it.
PostPosted: Mon Aug 27, 2018 12:46 pm
No, you don't have to use accelerator. I usually do only because I don't want to wait idunno
PostPosted: Mon Aug 27, 2018 5:52 pm
I do this for a living and to my eye I can see CA pretty easy on Nitro finish
on poly I can see it in good light
PostPosted: Tue Aug 28, 2018 7:33 am
Last Name: Colbert
City: Anacortes
I'll take a closer look.
PostPosted: Tue Aug 28, 2018 9:56 am
First name: Tim
Last Name: Benware
City: Creedmoor
Zip/Postal Code: 27522
Steve, I use glue boost and have some if you'd like to try it out. I need to order some more accelerator.
"I've been had again"
Tim Benware
Creedmoor, NC
PostPosted: Mon Feb 04, 2019 8:43 am
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Yes, and not so favorable. First guitar, first Nitro finish. I just used Gluboost after the final coat had dried for drop fill, and to repair a crack that appeared due to low humidity. After leveling and polishing, somewhere in the process, the GLUBOOST shrank back along the 12" long crack, leaving a low trough, quite visible and unacceptable. I've drop filled again, over the CA with many coats of lacquer. Letting it dry for 7 days before I go back and level. Other places where I drop filled with Gluboost sank/ shrank back, requiring additional work. Had a little accidental dribble onto the surface, it shrank back too. Might be dry time, I only let the CA dry overnight, but I'm not a fan
Measure Twice,
Karl Borum
These users thanked the author Kbore for the post: Pmaj7 (Wed Feb 06, 2019 9:43 pm)
PostPosted: Tue Feb 05, 2019 10:33 am
First name: Blake
Last Name: Dyson
City: Hillsborough
Zip/Postal Code: 27278
I have had bad experiences filling with super glue under water based lacquers, sometimes it has left me with white spots. I fill with finish instead and take my time.
These users thanked the author Luthier1975 for the post: Pmaj7 (Wed Feb 06, 2019 9:40 pm)
PostPosted: Tue Feb 05, 2019 2:39 pm
I have found that using CA to drop fill is ok, but it's a different hardness than EM6000 and the Nirto Lacquer I've used in the past, thus it tended to look different after the final buffing.
If you have time, use the EM6000. It's the same finish, will melt in and will look the same after you've spent all that time leveling and buffing...
I've never used gluboost so I have nothing to say about it. But, a glue and your finish are different animals. As this is on a new guitar, don't cut corners. Give it the time required and it'll be as close to perfect as you can get it.
These users thanked the author Rod True for the post: Pmaj7 (Wed Feb 06, 2019 9:40 pm)
PostPosted: Wed Feb 06, 2019 7:03 pm
Gluboost is probably better than most CA glues but it still doesn't disappear like a drop fill of the same finish will.
These users thanked the author Barry Daniels for the post: Pmaj7 (Wed Feb 06, 2019 9:44 pm)
cron
