It is currently Fri Jul 25, 2025 5:11 am
 Post subject: Working with Ziricote
PostPosted: Tue Jan 15, 2019 1:30 pm
First name: Raul
Last Name: Ortiz
Hi all,
I recently had a birthday and I want to build something special to commemorate the big 4-0...
I found this Ziricote... I've never worked with it and have found most people find it a PITA to work with. Chips, cracks, the whole nine yards. I recently got a Fox style bending machine along with a silicone heating pad.
I'm always up for a challenge, but am I just asking for trouble?
Also, I'd appreciate any input on the wood... I love the look of it, does anything concern you from looking at the picture? Questions I should ask the seller?
I should add, I want to build a cutaway....of course
Thanks for any advice!
RaúlImage
Sent from my R1 HD using Tapatalk
PostPosted: Tue Jan 15, 2019 1:37 pm
Last Name: Ensor
City: Springfield
State: Missouri
I've only built one with Ziricote, but I love it as well. My first concern with the set pictured is it looks decently flatsawn- which may exacerbate ziricote's inherent problems.
When I built with it, I flooded all pieces with thin CA prior to bending/jointing. This helps with stability. It's a nasty process and adds some noxious fumes to the bending process (plus will require barriers between the wood and blanket/slats), but helps to fill any small internal issues you can't see.
http://elevatelutherie.com
http://ensorguitars.com
These users thanked the author Chris Ensor for the post: guitarradTJ (Tue Jan 15, 2019 1:54 pm)
PostPosted: Tue Jan 15, 2019 1:57 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I'm another fan of ziricote. I've only built one guitar with it so far. The back and sides set I used presented none of the problems on your list, but maybe I was just lucky. The only thing that stood out was that the sides took more effort to bend on my hot pipe than other woods. I pre-treated the sides with SuperSoft and they bent without cracking or cupping.
Here's a photo of the wood I used to compare with the wood you have:
These users thanked the author J De Rocher for the post: guitarradTJ (Tue Jan 15, 2019 2:01 pm)
PostPosted: Tue Jan 15, 2019 1:59 pm
First name: Raul
Last Name: Ortiz
Thanks for your advice. How did you like your results? Was it worth the trouble?
PostPosted: Tue Jan 15, 2019 2:08 pm
First name: Raul
Last Name: Ortiz
WOW! That's gorgeous!
About 70% of what I've read online talks about those problems... The rest say they've bent like butter. SS is a product that seems to come up a lot for a successful bend.
I love the look of it!
PostPosted: Tue Jan 15, 2019 2:53 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
I think I might build with ziricote for my own use, but never commercially...we've repaired too many cracks not to understand why the wood deserves its reputation.
- Beth Brower
These users thanked the author Woodie G for the post: guitarradTJ (Tue Jan 15, 2019 2:53 pm)
PostPosted: Tue Jan 15, 2019 2:57 pm
First name: Daniel
Last Name: Petrzelka
State: Washington
I've only built one with Ziricote and was fortunate to have a set that bent like butter. Would love to use it again.
Thinned sides to approximately .080"
Light misting with water on both sides
Wrapped in kraft/butcher paper
Sandwiched between two metal bending slats
Heated my silicone blanket to roughly 300°F
Was patient with the preheat
Bend smoothly with no cupping/splitting or creasing.
Planing the back/sides to thickness was the only area I needed to exercise caution. Use a very sharp smoothing plane on a skewed angle or cabinet scraper as its very hard and almost crumbly. If my plane was the least bit dull I would get slight crumbly tear-out.
With a sharp plane or fresh cabinet scraper it finishes like glass.
These users thanked the author dpetrzelka for the post (total 3): Pmaj7 (Tue Jan 15, 2019 5:52 pm) • guitarradTJ (Tue Jan 15, 2019 3:51 pm) • Ernie Kleinman (Tue Jan 15, 2019 3:41 pm)
PostPosted: Tue Jan 15, 2019 3:51 pm
First name: Raul
Last Name: Ortiz
That's beautiful!
How was it gluing?
PostPosted: Tue Jan 15, 2019 3:58 pm
First name: Daniel
State: Washington
It doesn't seem oily all (so that was not a concern), but on any wood with this hard of a surface, I usually wipe with naphtha to be sure there is no surface contamination before gluing. I used both hot hide glue and Titebond I without any issues.
These users thanked the author dpetrzelka for the post: guitarradTJ (Tue Jan 15, 2019 4:21 pm)
PostPosted: Tue Jan 15, 2019 4:20 pm
Last Name: Ensor
City: Springfield
State: Missouri
Well worth the insurance to flood it in my opinion (same goes for BRW and others that tend to crack with time). I'm happy with the results:
I used it for the B/S, bridge, fingerboard, and headstock overlays. I'll echo what Daniel said- it sure is crumbly. I found it unpleasant to carve for my bridge.
These users thanked the author Chris Ensor for the post: guitarradTJ (Tue Jan 15, 2019 4:22 pm)
PostPosted: Tue Jan 15, 2019 4:23 pm
First name: Raul
Last Name: Ortiz
Sooo lovely... Thanks for your advice!
PostPosted: Thu Jan 17, 2019 12:14 am
First name: Kerry
Last Name: Werry
City: Coquitlam
State: British Columbia
I've built one and just closed the box on a second ( a commission) it bends OK, I bend it @ 295 and that seems plenty.. Cracks and splits easy until closed up then seems fine.. I don't flood with CA but do use a few extra side braces.. My first was for me and it is 4 years old no issues just left sitting on a a stand..
Kerry
My Website http://klw-strings.com
My Luthier's Blog...http://klwstrings.blogspot.com
These users thanked the author kwerry for the post: guitarradTJ (Thu Jan 17, 2019 3:04 am)
PostPosted: Thu Jan 17, 2019 11:18 am
First name: Tim
Last Name: Benware
City: Creedmoor
Zip/Postal Code: 27522
I had none of the problems expressed and did nothing differently than I have with mahogany or EIR.
"I've been had again"
Tim Benware
Creedmoor, NC
These users thanked the author Ben-Had for the post: guitarradTJ (Thu Jan 17, 2019 12:01 pm)
PostPosted: Thu Jan 17, 2019 1:14 pm
I've built two. The first is 4 years old the second 3 years old, no issues with either one. Both sets were well-seasoned, no problems with splitting nor bending. These were steel string, but I'm considering a classical or two with Ziricote.
These users thanked the author Pat Foster for the post: guitarradTJ (Mon Jan 21, 2019 1:26 pm)
cron
