It is currently Wed Aug 13, 2025 4:29 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
 Post subject: Re: Bending Technique
PostPosted: Tue Jan 29, 2019 9:39 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Does the ammonia used in bending alter the color of some woods? Perhaps it is not strong enough to matter? I have seen articles about brushing ammonia onto wood rather than fuming it.
Bryan Bear PMoMC
PostPosted: Tue Jan 29, 2019 10:49 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
I don't believe the current environmentally-focused Windex formulation actually contains any ammonia - the current SDS for Original Windex shows Isopropanol, 2-Butoxyethanol, Ethylene glycol n-hexyl ether, water, fragrance and blue dye. I found one reference to ammonium hydroxide (ammonia water) on the SC Johnson website (as in "...Windex Blue... does contain ammonia..."), but the SDS does not reflect that as a hazardous ingredient. Given the ammonia smell in some types of Windex, it seem like it is certainly in the mix in some formulations of the cleaner, but straight household ammonia is about 5-10 percent ammonia, which would be close the pre-2006 Windex formula of 5% ammonia by volume.
- Beth Brower
These users thanked the author Woodie G for the post: Pmaj7 (Thu Jan 31, 2019 12:39 pm)
PostPosted: Tue Jan 29, 2019 4:24 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Bryan, I bet the color changing ammonia is not the stuff u get at the grocery store. Woodie, kind of what I thought. Maybe John can look at ingredients on his windex bottle
Active ingredient in Super Soft II is Diethylene Glycol Monoethyl Ether, maybe there is a similar type in Windex?
PostPosted: Tue Jan 29, 2019 4:39 pm
State: West Somerset
Country: UK
John thanks I am OK with the temperature scales but your method has given me something to think about.
PostPosted: Tue Jan 29, 2019 5:53 pm
here is what I can tell you. My windex says it has ammonia D what ever that is. I can tell you I don't have the water staining that SS2 had and it does work better than plain water.
I can say this with certainty Wood is stupid , get it hot it will bend. I know some people use downy in the water , I have tried that can't say it helped or hurt. I can't take all the credit for windex but I heard this from a few people including our own member here Bob Gleason.
PostPosted: Tue Jan 29, 2019 7:03 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Thanks John. Just alerting folks that might try ur technique that there are multiple formulations out there for Windex. Ammonia is considered by many as an irritant. So they make versions without it. Often it will say "ammonia free" on the label.
These users thanked the author Mike OMelia for the post: Pmaj7 (Thu Jan 31, 2019 12:41 pm)
PostPosted: Fri Feb 01, 2019 8:53 am
bluescreek wrote:
I use widex right off the shelf and no soaking just spray and bend. We will be shooting new videos shortly to show the new technique.
I find that the temps can be used across the board. The one thing is that some woods like less moisture than others. Maple and Mahogany especially like less moisture. You won't hurt the wood even up to 400F for a short time. Lace wood will scorch faster than any orther woods but even that can handle 350
In all I am done heating in about 7 minutes
it takes me about 4 min to bend from the time I turn on the machine and about another 3 to reach my desired temp. Also thickness of the wood will come into play. I seldom bend thicker than .075 +/- .005
I was actually looking for some new vids an hour ago:)
cron
