It is currently Tue Jul 22, 2025 8:45 am
PostPosted: Tue Feb 05, 2019 8:02 pm
First name: David
Last Name: Riedmiller
State: WI
At this point it is more agony. Brazilian Rosewood side bending disaster. My Bad. The good part is I know what went wrong and why, and have been making positive changes to my Fox style bender. And my technique. My question to this excellent guitar building community; anyone know of a replacement side set of BRW? Help of any kind would be appreciated.
"It is easier to fool a man, than it is to convince him that he has been fooled"
Mark Twain
PostPosted: Tue Feb 05, 2019 8:34 pm
I am here only as a last resort. I want to keep mine, but I have sympathy, too. It might have to be a set with minor worm holes. So, I hope someone else offers a solution.
PostPosted: Tue Feb 05, 2019 11:02 pm
What exactly was the problem then?
PostPosted: Tue Feb 05, 2019 11:19 pm
First name: David
State: WI
The benders waist caul was tipped. Because the shoe was a sloppy fit in the bender. So after I bent upper and lower bouts I snugged the waist down the last quarter inch. but the side was not perpendicular to the mold at the waist. (it was up perhaps a half inch at the tops edge, less at the backs edge. Ended up with cracks cross the grain. I spent hours today rebuilding the bender to prevent this from happening in the future. Expensive lesson. Ouch.
Mark Twain
PostPosted: Tue Feb 05, 2019 11:22 pm
First name: David
State: WI
I can accept a few worm holes, since the back from the set has a few.
Thanks for the sympathy. I'll be licking this wound for a while!
Mark Twain
PostPosted: Wed Feb 06, 2019 11:16 am
If you are interested in doing laminated sides from veneer I may be able to help you out. BRW comes in a lot of colors and shades so pictures of the back panels would aid in matching the set.
PostPosted: Wed Feb 06, 2019 11:49 am
Ah bummer, yeah I can see how that could happen.
PostPosted: Wed Feb 06, 2019 12:17 pm
By the way, you can still iron it flat and use it for head pieces or for ukulele backs and sides.
PostPosted: Wed Feb 06, 2019 12:29 pm
First name: Freeman
Last Name: Keller
Can't help with the Braz, but I remember a seminar with Charles Fox at a GAL convention a while back. He was demonstrating side bending, mahogany with a cut away and - SNAP. He took the two pieces out of the bender, looked at the audience and said "that happens"
PostPosted: Wed Feb 06, 2019 2:10 pm
First name: David
State: WI
Appreciate the sympathy. Still kicking myself for not being more focused on what was I was doing.
I’ve been considering laminating sides-
a definite advantage for a couple reasons.
Mark Twain
PostPosted: Wed Feb 06, 2019 2:11 pm
First name: David
State: WI
What do you use as the inner veneer?
Mark Twain
PostPosted: Wed Feb 06, 2019 3:14 pm
First name: David
State: WI
Clay- this is the BRW back.
Mark Twain
PostPosted: Wed Feb 06, 2019 3:42 pm
Getting a veneer and doing double sides is a great idea. You may get a better sounding guitar and become a double sides believer as fringe benefits.
PostPosted: Wed Feb 06, 2019 6:10 pm
Hi David,
I can look through the veneer this weekend. How long and wide do the side pieces need to be?
Generally I do 3 layers of rosewood, but many people use mahogany, walnut, or some other wood species for the inner layer.
PostPosted: Wed Feb 06, 2019 9:15 pm
First name: David
State: WI
Clay S. wrote:
Hi David,
Clay it is a Small Jumbo, 32 long, 4 1/2 at the end wedge. It will need Brazilian inside and out.
Thanks!
Mark Twain
PostPosted: Sat Feb 09, 2019 6:05 pm
Hi David,
This is what I found. The pieces are approx. 3 ft X 7 1/2 inches. I will send you a PM on the particulars ( I don't know how to send pictures in a P.M.
PostPosted: Sat Feb 09, 2019 7:23 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Dake Traphagen posted some BRW in the classifieds a while back.
I suspect he still has some - you can email him if you're still looking.
He was listing sets but he may have orphans.
I'm not a luthier.
Users browsing this forum: jfrench and 15 guests
