It is currently Fri Jul 18, 2025 8:40 pm
PostPosted: Mon Feb 18, 2019 4:46 pm
I am nearing the end of my first build but I have a question that has been on my mind for a while, and would like to get some confirmation from experienced builders before I start another.
I made my braces by cutting close to the final radius on the band saw then used the radius dishes to sand them. When I sanded them on the dish, I tried to sand the brace near it’s actual location holding it as straight vertically as possible on the dish. I was thinking that if I just sanded a radius on the braces then when installed the braces would need to be normal (90 degrees) to the radius surface and each brace depending on its final location would be on a different vertex. But maybe this is acceptable. Would like to get this figured out before the next build.
PostPosted: Mon Feb 18, 2019 5:06 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
No need to cut them on the band saw. A bench hook and a few strokes with a plane, then clean up in the dish. You may not need the dish if you're good with the plane.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Mon Feb 18, 2019 6:02 pm
If I’m understanding right, you’re worried about the angle between the brace bottom and the side of the brace?
The radius is so big that you don’t really need to worry about it. Sand it wherever you want in the dish and just keep the brace perpendicular as best you can.
PostPosted: Mon Feb 18, 2019 9:51 pm
To add to this
Sand a certain number of strokes then flip it around and do the same number.
I do this to keep the bottom of the brace flat and avoid leaning to one side or another. It’s terribly hard to get a flat bottom for me unless I do that
PostPosted: Mon Feb 18, 2019 9:59 pm
Sand them in the dish in pairs. This widens the collective bottom to prevent tipping...
These users thanked the author meddlingfool for the post: Pmaj7 (Tue Feb 19, 2019 1:45 am)
PostPosted: Tue Feb 19, 2019 4:42 am
I rough in braces on a router jig and sand in pairs similar to Ed, and also flip them round like SnoManSnow.
Maybe it's OCD, but I use shop made radius blocks with increasing grades of abrasives because my radius dishes have 60 grit in them.
The blocks go 100, 120, 180 to 240 grit, and I lightly mark the braces bottoms with pencil to see when they are done on each grit.
Also use the radius blocks to sand the rims to the higher grits for the plate domes.
PostPosted: Tue Feb 19, 2019 11:02 am
First name: Tony
Last Name: Thatcher
City: Bozeman
State: MT
I used to worry sanding each brace in its approximate location, but only for the back braces. I think I saw this on some web site and thought it was good idea. I found it difficult to do consistently and ended up with poor fits to the top when gluing up. Now I do what meddlingfool does, and sand them in pairs or three's and it works great. I also hit them with a plane first to get the basic curve, only finalizing in the dish.
Tony Thatcher
Bozeman, Montana
PostPosted: Tue Feb 19, 2019 11:21 am
First name: Larry
Last Name: Hawes
Was always curious about how the back brace 'should' be radiused. Perpendicular to the center of the dish where they all basically sit 'vertical' to that center? or should they be radiused perpendicular to the edge of the dish where they will be located?
Bad drawing attached
Thank You and Best To All
PostPosted: Tue Feb 19, 2019 11:36 am
The difference is minimal and inconsequential.
PostPosted: Tue Feb 19, 2019 11:38 am
First name: Larry
Last Name: Hawes
Thanks Barry, was thinking the same thing but sometimes thinking can be my worst enemy...
PostPosted: Tue Feb 19, 2019 12:44 pm
For me it's inconsequential due to my process.
First I cut the rectangular brace. Then I use a jig that get it really close on the edge sander but with a spline curve. Then I sand the ends to thickness on the drum of the edge sander. Then I mark the center width of the brace and taper the sides on the edge sander. The likelihood of getting them exactly symmetrical is pretty slim, so worrying about whether they're slightly tilted by a smidgen one way or the other is pointless...
PostPosted: Tue Feb 19, 2019 2:10 pm
I radius braces using a hand plane setup that makes the gluing surface perpendicular to the side of the brace. Thus the brace is 'normal' to the surface of the arch when it's glued up. As my calculus prof used to say: "As the djangle goes to djero, the sine of the djangle also goes to djero. What I mean I am now explaining" He was from India... Anyway, the point is that when you're within about 3 degrees of perpendicular, it hardly matters. What's really important, though is getting that surface flat across the width of the brace, and making sure there is no twist from end to end. Yeah, I know, technically the bottom of the brace should be radiused across the width too, but the difference between 'flat' and a 15' radius over 5/16" is, as they say, 'small'. Making that surface perpendicular to a flat face of the brace ensures that there's no twist, and, of course, it's easy to check for roll on a flat surface.
PostPosted: Tue Feb 19, 2019 2:49 pm
You can also set up a fence in your radius dish if you're really concerned about rolling them...
PostPosted: Thu Feb 21, 2019 12:52 am
Yes, this was the intent of my original question. Guess I couldn’t find a way to word it. So from what I gather here it really doesn’t matter much if the braces are tilted a little as shown in the first DWG.
PostPosted: Thu Feb 21, 2019 10:17 am
Last Name: Sollod
The brace is going to be carved anyway, so I would think that it doesn't matter if isn't quite perpendicular...
www.swiftcreekguitars.com
PostPosted: Fri Feb 22, 2019 7:38 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
I recall a thread or two on this in the archives, and the two views expressed seemed to sort as a) it does not really matter, as the loads are normal to the back so anything close to square is fine, and b) my OCD is really kicking in today, so the only acceptable solution is (fill in blank). We come down closer to a) than b), with Mr. Sollod's observation highlighting the related task of - having glued the braces on square or at some angle - maintaining that desired angle in the carved and voiced brace.
- Beth Brower
