It is currently Thu Aug 07, 2025 5:00 pm
PostPosted: Fri Mar 08, 2019 2:48 pm
This hold down fixture improved the quality of my work quite a bit. I easily planed the back and top to thickness using this. I also cut the rosette channels using a waster board under the top plate on it. Next guitar I’m going to use it with two accessory boards to join the plates. Easy to make and inexpensive. 2 ea 3/4 Mdf glued together for a 1-1/2 thick base, some scrap oak from an old pallet used for the clamps, toilet flange bolts and t knobs.
These users thanked the author 6string for the post: dpetrzelka (Fri Mar 08, 2019 6:45 pm)
PostPosted: Fri Mar 08, 2019 3:49 pm
Nice. I use something similar, but like your clamping arrangement better than mine.
Might have to nick that part. ;)
PostPosted: Fri Mar 08, 2019 4:11 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
That looks great. Thanks for sharing the idea and the design.
PostPosted: Fri Mar 08, 2019 4:55 pm
Last Name: Miller
City: Wood Dale
State: Illinois
I like it!!! I either have to make a board like this so I can hand thickness my plates, or build a drum sander. Thanks for sharing.
PostPosted: Fri Mar 08, 2019 7:00 pm
I like that, simple idea, well executed.
PostPosted: Fri Mar 08, 2019 7:51 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I like it! I might build one with just a number of holes in strategic spots, rather than slots. Slots take effort with a router, whereas holes just need a Forstner bit (for the head of the bolt) and regular twist bits (for the shaft of the bolt). Great idea, though.
PostPosted: Fri Mar 08, 2019 8:43 pm
I'm thinking along the same lines. Mine is MDF too, and I don't like machining that material more than I have to.
PostPosted: Fri Mar 08, 2019 9:03 pm
Last Name: Beaver
City: Lake Forest
Well done !!! Great design, and I really like that top. Looks like a good one.
Joe Beaver
Maker of Sawdust
PostPosted: Sat Mar 09, 2019 1:26 pm
First name: George
City: Seattle
Nice jig.
I will say that using a "waster board" that does not extend beyond the perimeter of the top would make me nervous. It doesn't take much pressure to snap a plate that is not fully supported.
George :-)
PostPosted: Sat Mar 09, 2019 3:04 pm
George L wrote:
Nice jig.
The waster board is not shown in the pics, I did have one that was a bit larger than the top plate. The pic shown was taken after the waster board and centering pin were removed.
PostPosted: Sat Mar 09, 2019 6:39 pm
"I like it! I might build one with just a number of holes in strategic spots, rather than slots. Slots take effort with a router, whereas holes just need a Forstner bit (for the head of the bolt) and regular twist bits (for the shaft of the bolt). Great idea, though."
You can cut slots easily enough with a table saw, and even dado out the sides to recess the bolt heads if you want to. It might be less dusty than using a router.
PostPosted: Sat Mar 09, 2019 7:58 pm
I suppose that depends on your dust collection set up but you're still pulverizing the same volume of "waswood".
PostPosted: Sat Mar 09, 2019 8:33 pm
First name: George
City: Seattle
Cool. That's how I'd go about it as well. I thought it was your waster board that is elevating the plate off the work surface in the fist pic.
George :-)
PostPosted: Sat Mar 09, 2019 10:00 pm
No that’s actually the back plate. Just have them both clamped down while waiting to cut some bracing.
PostPosted: Sun Mar 10, 2019 8:01 am
Clay S. wrote:
"It might be less dusty than using a router."
Steven Wheeler:
"I suppose that depends on your dust collection set up but you're still pulverizing the same volume of "waswood"."
Hi Steven,
That's why I used the weasel word "might" To me the slots look like they would be more useful than drill holes, and with a cabinet saw most of the sawdust goes inside the cabinet, with a contractor saw that might not be the case. Weasel words can be very handy at times. They lend a bit of imprecision to one's statements to make them definitely indefinite.
From the web:
"Weasel words and phrases include “may,” “might,” “could,” “can,” “can be,” “virtually,” “up to,” “as much as,” “help,” “like,” “believe,” “possibly,” and similar qualifiers that create enough wiggle room for a rhino. Some of the weasel words are qualifiers." [:Y:]
These users thanked the author Clay S. for the post: Pmaj7 (Sun Mar 10, 2019 8:04 pm)
PostPosted: Sun Mar 10, 2019 10:03 am
Clay S. wrote:
Steven Wheeler:
Hi Steven,
From the web:
So does that mean that your not going to build one anyway. In your first post you said “ I might build one “. :lol:
Users browsing this forum: dofthesea and 26 guests
