It is currently Wed Jul 23, 2025 8:40 am
PostPosted: Mon Feb 28, 2005 1:14 am
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
I have a solid paduk 1/8" ring inside enlarged soundhole-now hole =4". Do I need the soundhole braces or need to modify them. Guitar OM
PostPosted: Mon Feb 28, 2005 2:16 am
I would say, yes. The braces that run from the upper arms of the X to the upper traverse brace stiffens the area that has been weekened by the should hole cutout.
I use 3 here, for my om's one on each side of the sound home and one across the bottom above the X.
You can almost see the brace below the sound hole.
PostPosted: Mon Feb 28, 2005 3:04 am
Lance,
Have you ever not scaloped the braces on your OM? Just wondering if might have, and what difference you may have noticed.
Thanks!
Jeff
PostPosted: Tue Mar 01, 2005 4:02 am
Dang, Lance...that bracing structure sure looks familiar.....
PostPosted: Tue Mar 01, 2005 4:32 am
[QUOTE=HankMauel] Dang, Lance...that bracing structure sure looks familiar..... [/QUOTE]
PostPosted: Tue Mar 01, 2005 4:33 am
Nope -- never tried that .
