It is currently Sun Jul 13, 2025 7:25 am
 Post subject: Martin 2-17 plans?
PostPosted: Thu May 23, 2019 5:40 pm
Where can I purchase plans for a Martin 2-17 … or any size 2 Martin?
 Post subject: Re: Martin 2-17 plans?
PostPosted: Thu May 23, 2019 8:18 pm
Last Name: Colbert
City: Anacortes
You’ve likely already seen this. http://217.dougschmude.net/index.html Looks like enough info to draw it up yourself.
Best, M
PostPosted: Thu May 23, 2019 8:47 pm
I got the 1-17 plans from LMI which I base my parlour on. Maybe you could use it as a base to size up?
I wonder if John Arnold or Frank Ford may have plans? I believe they've been known to draft rough plans off of guitars in for repair...
PostPosted: Thu May 23, 2019 9:17 pm
That's interesting. I thought 2 was smaller than 1 for some reason. I'll check dougschmude.net.
PostPosted: Thu May 23, 2019 10:30 pm
Size 2 is smaller than size 1, but not by a lot. The body shape follows the same general proportions. If you have the size 1 plan and the specifications listed on the Doug Schmude page you can draft a fair approximation. Even the originals had some variation in size, so one that varied a 1/4 inch in the lower bout could be a small size 1 or a large size 2 depending on the other specs.
PostPosted: Fri May 24, 2019 12:46 am
I actually don’t know what the numbers mean. Could be size down...
PostPosted: Fri May 24, 2019 6:15 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
The specs listed on that site show the depth as being deeper at the heel than the tail.?. Can we assume those numbers are just transposed, or were they really made that way?
Bryan Bear PMoMC
PostPosted: Fri May 24, 2019 6:37 am
"The specs listed on that site show the depth as being deeper at the heel than the tail.?. Can we assume those numbers are just transposed, or were they really made that way?"
The body depth numbers are wrong. Most sites list the body depth at 4 inches, which would be in the lower bout. Upper bout would probably be 3 3/4 or 3 5/8 inches.
PostPosted: Fri May 24, 2019 8:14 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
That was my assumption but I've never seen one of these and thought it could be an interesting quirk. . .
Bryan Bear PMoMC
PostPosted: Fri May 24, 2019 8:38 am
I own a number of these. They are not X braces and were fan braced instruments.
What time period are you looking to copy ? Mine is from 1847 according to martins records.
PostPosted: Fri May 24, 2019 9:21 am
I'm looking for the steel-string braced, 1922 model. I used to own one some time ago, but I didn't regret selling that much because it had numerous repairs. Instead of risking another vintage piece, building one should be way better.
PostPosted: Fri May 24, 2019 12:53 pm
My research indicated that Martin didn't start using steel strings until the late '20s. A 1922 model should still be gut strings.
PostPosted: Fri May 24, 2019 1:38 pm
The 17 series when converted to mahogany tops in 1922 were also braced for steel - the first Martin guitars built for steel strings, and also their lowest priced guitar. Other models were braced for steel on a regular basis in the late 20's.
PostPosted: Fri May 24, 2019 4:23 pm
Like I said, I used to own one and it was braced for steel … and stamped behind the headstock without a logo. pizza And when I got it, a critter made it its home. Don't know what species it was.
PostPosted: Fri May 24, 2019 7:32 pm
Thanks for the clarification, Clay. I learned something today.
I am currently restoring a 1931 00-17 that someone had replaced the top with spruce and other modifications. I'm taking it back to original specs. One thing I can't find out is what type of side reinforcements were originally used: wood braces or linen?
PostPosted: Fri May 24, 2019 8:13 pm
I had a couple of 17 style guitars, an O-17 from the late 30's and a OO-17 from the mid 50's IIRC. I don't remember seeing side reinforcements in either of them. It was a while ago - back then they were bought and sold in good playing condition for about $100.
PostPosted: Thu May 30, 2019 6:25 pm
I found my beat up copy of Longworth's book that lists dimensions for the various sizes of Martin guitars. Here are some of the dimensions for size 2 in inches:
totl length 37
bod len 18 1/4
Width up bod 8 1/2
width low bod 12
depth up bod 3 3/4
dep low bod 4
fing bd width@nut 1 13/16
fing bd@12frt 2 1/4
dia snd hole 3 1/2
scale length 24.5
With a copy of a size 1 plan I'm sure you could make the necessary adjustments and come pretty close. If you compare dimensions from Longworth against Schmude's you will notice some differences. It may reflect differences in the individual instruments measured and in some cases errors of measurement ( I would hesitate to use a 2 3/8 in. string spacing @ bridge with a F.B. width of 2 1/4 in.@12th fret.)
These users thanked the author Clay S. for the post: KawaiianPunch (Fri May 31, 2019 4:03 pm)
PostPosted: Fri May 31, 2019 2:15 am
First name: Tim
Last Name: Allen
City: San Francisco
Robert Corwin has some lovely--and very instructive--pictures of the inside of his 1930 2-17 here: http://www.vintagemartin.com/styles15_17_18.html
When you carve the braces this would be very helpful as a resource. He also gives the dimensions and other details. As has often been said here, that site is a wonderful resource!
Tim Allen
"Never hurry, never rest."
These users thanked the author TimAllen for the post: KawaiianPunch (Fri May 31, 2019 4:04 pm)
PostPosted: Fri May 31, 2019 4:13 pm
Thanks Clay S. and TimAllen.
Do y'all know if they had a back-radius? I can't remember if the one I had did.
PostPosted: Sat Jun 01, 2019 10:04 am
I think most of the guitars I've run into have had a slight back radius, even the "early romantic" ones. Without some arching the backs would tend to look concave.
PostPosted: Sat Jun 01, 2019 10:17 am
The one I am working on has a non-spherical back radius. Side to side it is about 25' radius, and top to bottom it is about 15' radius. This is consistent with descriptions that I have read online.
These users thanked the author Barry Daniels for the post: KawaiianPunch (Sat Jun 01, 2019 10:56 am)
PostPosted: Sat Jun 01, 2019 4:24 pm
I found my 2 patterns from the old martin factory. the first steel martin production guitar
the link was not correct in any of the specs clays listing from the martin history is correct
by this time the back braces were reduced to 4 not the 5 of the original , the ladder and fan braces were
now 1/4 in X.
In the early 20s we see the beginning of the modern martin guitar.
These users thanked the author bluescreek for the post: KawaiianPunch (Wed Jun 05, 2019 7:59 am)
PostPosted: Sat Jun 01, 2019 11:28 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Clay, did that book list the body length for the size 1?
Bryan Bear PMoMC
PostPosted: Sun Jun 02, 2019 7:12 am
Hi Bryan,
Here is what it lists for the size 1 (in inches):
ttl len 37 3/4
bod len 18 7/8
wid bod up 9 1/4
wid bod low12 3/4
dep bod up 3 3/8
dep bod low 4 3/16
wid F.B.@nut 1 7/8
wid F.B.@12th frt 2 5/16
dia snd hole 3 9/16
Scale Len 24.9
These users thanked the author Clay S. for the post (total 2): KawaiianPunch (Wed Jun 05, 2019 7:58 am) • Bryan Bear (Sun Jun 02, 2019 11:52 am)
PostPosted: Sun Jun 02, 2019 11:16 am
https://www.martinguitar.com/features-m ... /sizetype/
this may be helpful;
These users thanked the author bluescreek for the post (total 2): KawaiianPunch (Wed Jun 05, 2019 7:58 am) • Bryan Bear (Sun Jun 02, 2019 11:54 am)
Users browsing this forum: Chris Ide and 22 guests
