It is currently Wed Aug 06, 2025 11:35 am
PostPosted: Mon Mar 27, 2006 6:54 am
I just inlaid two fretboards with identical gold MOP sets. It is the snowflake set from Andy DePaul. One FB came out perfect. On the other, however, one of the small (1/4" square) diamonds turned during clamping. (should have CA'd it in place and packed dust around it, but I didn't). It is an ebony board, the diamond is firmly attached with ebony dust in epoxy, and has dried very hard. Do I live with it or is there a way to remove it and straighten it up? The guitars are for my sons. Of course, I would like them to be perfect, but I'm afraid I'll do a lot more damage trying to remove it. Can I soften that epoxy enough to remove and replace that one item?
PostPosted: Mon Mar 27, 2006 8:07 am
Ron, sorry to hear that, i'll let the experts answer you but maybe a source of electric heat applied right over it should soften it up enough for you to go in there and take it out? I'm thinking about maybe routing it out with a dremel, fill up and restart but as you know, it's on ly worth my newbie's advice! Good luck in fixin' this bud.
PostPosted: Mon Mar 27, 2006 8:10 am
You can take a hot soilder iron to the pearl till the CA smokes then remove the pearl. MichaelP38803.7156481482
PostPosted: Mon Mar 27, 2006 12:30 pm
Last Name: Beaver
City: Lake Forest
With epoxy, getting it hot enough to pop may damage the fingerboard. I'd test with a piece of scrap first.
I'm thinking you are going to have to route it out with a good end mill and a solid grip. the ebony will be softer than the pearle so be careful!)... And good luck to you.
Joe Beaver
Maker of Sawdust
PostPosted: Mon Mar 27, 2006 1:45 pm
Thanks, guys
Anyone else have input on the feasibility of using the soldering/woodburning pen to heat the pearl? I might try that tomorrow, but sure don't want to hurt the FB as it has about 15 other inlays in it and is ready to attach to the neck. A lot of work to mess up now.
PostPosted: Mon Mar 27, 2006 1:54 pm
Personally I would rout it out and re do it. Just my thought.
PostPosted: Mon Mar 27, 2006 2:00 pm
Ron, whatever you decide, i'm with you, i'll be sending positive vibes your way bud!
PostPosted: Mon Mar 27, 2006 2:34 pm
Thanks, Serge, I can feel those vibes now.
PostPosted: Mon Mar 27, 2006 2:35 pm
First name: Craig
Last Name: Lavin
City: Sunrise
State: Fl
Zip/Postal Code: 33323
I am in the process of routing out a whole 3" butterflyfish half in an otherwise perfect headstock (with two other fishes that are fine) because the new material I tried didn't work.
Believe me your is an easier job
Craig. L
www.handcraftinlay.com
PostPosted: Mon Mar 27, 2006 2:37 pm
I've always heard that Indian rugs are woven with intentional mistakes in them. To avoid perfection.
I'm always letting my kids know their old man isn't perfect!
And I'm sure the guitars I build for them will defintely have some "character"!
PostPosted: Mon Mar 27, 2006 2:45 pm
[QUOTE=ATaylor] I've always heard that Indian rugs are woven with intentional mistakes in them. To avoid perfection.
And I'm sure the guitars I build for them will defintely have some "character"![/QUOTE]
Really wise thinking Alan. A nice way to apease oneself.
PostPosted: Mon Mar 27, 2006 11:31 pm
I like that, too, Alan. Thanks, and thanks Craig. Good luck with yours.
PostPosted: Tue Mar 28, 2006 2:13 am
Last Name: Bordeaux
City: Massena
State: New York
Zip/Postal Code: 13662
Ron,
I would just rout it out and replace with another. Much less time spent doing so .
Paul Bordeaux
http://www.bordeauxinlay.com
PostPosted: Tue Mar 28, 2006 7:14 am
Last Name: Beaver
City: Lake Forest
[QUOTE=old man] I just inlaid two fretboards with identical gold MOP sets. Ron[/QUOTE]
Ron,
How did you make out on this? Hope it went well.
Joe Beaver
Maker of Sawdust
PostPosted: Tue Mar 28, 2006 7:16 am
Last Name: Beaver
City: Lake Forest
If Paul Bordeaux says rout then I would rout. He is someone that knows.
Joe Beaver
Maker of Sawdust
PostPosted: Tue Mar 28, 2006 1:06 pm
Joe, I agree that Paul and Craig are the experts here. The problem with routing it out, though, it would have destroyed the piece and I didn't have another gold piece to replace it with. Anyway,
I used my woodburning pen with a flat tip and applied heat only to the top of the pearl (1/4" square). After a few seconds, the epoxy softened and I lifted the piece out with my exacto blade. Worked like a charm. I cleaned it off, cleaned the hole and reinstalled the piece. I'm pleased with the result.
Thanks everyone for the help.
PostPosted: Tue Mar 28, 2006 2:03 pm
Ron, congrats! Nothin like the satisfying feeling of a disaster averted! I'll bet the reason Paul and Craig suggested routing it out was that normally the amount of heat required to loosen a piece of pearl can make it so brittle so as to make the piece unuseable. It must have been a combination of the right touch and the luthier gods lookin over your shoulder! Good stuff!
PostPosted: Tue Mar 28, 2006 3:05 pm
Thank God i was the first one to give you that brilliant advice AHEM!!!!!AHEM!!!! AHEM!
just kiddikg Ron, i wasn't sure if i was gonna write this the first time, fearin' the experts would laugh at this suggestion but it turns you beat us all with another brilliant idea of yours!
Congrats dear friend, i'm very happy for ya!
PostPosted: Wed Mar 29, 2006 12:11 am
It had worked for me in the past. I figured it would for you. I had little worry with the epoxy. I was more cocerned with the CA and wood dust filler. The epoxy softens pretty quick but sometimes the CA will hold on till it almost cooks. Glad this worked out for you Ron
PostPosted: Wed Mar 29, 2006 12:34 am
Last Name: Bordeaux
City: Massena
State: New York
Ron,
great news!
Paul Bordeaux
PostPosted: Wed Mar 29, 2006 12:43 am
Last Name: Beaver
City: Lake Forest
Good Job.... it's good when a plan works....
Joe Beaver
Maker of Sawdust
PostPosted: Wed Mar 29, 2006 2:11 am
First name: Craig
Last Name: Lavin
City: Sunrise
State: Fl
I almost only use CA as a backing/filling glue becuase it seems to hold much stronger than epoxy. It also doesn't really ever let go, hence the routing I have to go through now.
I do use CA remover after I get to the bottom end of the route when I remove a piece, which is rarely, but it does soften it up enough to work it. It needs almost overnight to sit.
Craig L.
