It is currently Mon Jul 28, 2025 9:54 pm
Post new topic Reply to topic  [ 67 posts ]  Go to page Previous  1, 2, 3
PostPosted: Wed Sep 25, 2019 6:20 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Regarding the work holding tangent: there are solutions to that problem, but that problem is not the culprit when it comes to an ill-fitted dovetail. A router only gets the parts of a dovetail joint into the right basic shape. The real fitting of the joint is done by hand. If you are expecting the parts to go together perfectly right after routing, that is an unrealistic expectation. So, sure, find solutions to your work holding problem while routing (they exist), but that won’t make your dovetail joints fit right. Several times now, I and others have recommended that you watch John Hall’s YouTube videos on fitting a dovetail. When you watch them, note whether you see John use any sort of vise or work holding jig while hand fitting the dovetail.
PostPosted: Wed Sep 25, 2019 6:53 am
Last Name: Colbert
City: Anacortes
Toonces wrote:
Tai,
You've impressed me with your humility and ability to handle the criticism of your idea in this thread -- and still stay civil and ask questions. It's a good quality. I will offer some criticism as well - you're workmanship seems to be a bit rough - the dovetail is not an easy joint to get correct and I believe the issues you have had are due to poor fit. Don't lose heart and keep at it - or try Trevor Gore's method. I use endgrain inserts and they are more than sufficiently strong for our purposes as luthiers. Lutherie requires a very high skill level for certain operations -- a perfect neck joint is one of those and something that I see even very experienced builders do poorly.
To a couple of you who posted -- Why the rudeness? I encourage you to be better human beings and act with more kindness.
Tai,
If my questions came off as rude, that was absolutely not my intention. One of the great things about this forum is that it tends to be a safe and kind place to ask questions and discuss this stuff.
I tend to sound curt when I write and I can come off sounding like a d*ck. Writing is not one of my superpowers...
Again my apologies.
M
These users thanked the author Michaeldc for the post: James Orr (Wed Sep 25, 2019 10:06 am)
PostPosted: Wed Sep 25, 2019 7:15 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Under any reasonable set of use or storage conditions, mahogany is already among the most stable of woods. As long as you choose not oven-roast your instruments for prolonged periods of time, there is nothing to fear with a dovetail joint in the wood other than from the maker’s issues with execution.
We had a client that brought us a D-35 packed in several baggies and a couple boxes. The instrument had been in the back end of his over-packed minivan when one of his children found the spare key fob and popped the rear lift gate...at 75 mph on I-64 en route to the Outer Banks. The case, along with a few other items, ended up tumbling along the highway, striking a bridge overpass abutment at 50-60 mph. We did salvage the tuners for the client.
I could use this example of a ‘failure’ to find fault with Martin’s construction methods and materials, and to suggest that - had Martin just fabricated the instrument using exotic alloys and build-in airbag sensors and systems - the instrument would be more serviceable. But that would be silly, now, wouldn’t it?
- Beth Brower
PostPosted: Wed Sep 25, 2019 7:46 am
Tai Fu wrote:
I think one of my biggest problem is workholding.
Yes! Holding things is a giant deal, and an issue easily forgotten once one hasn’t had the issue in a while.
There are lots of ways to skin this cat. My method was to just use a neck jig (I have the LMII one). I’m not sure if shipping would be an issue. However it does the job of holding the neck tight, the template in the right place, and let’s you use a router to a more precise degree.
PostPosted: Wed Sep 25, 2019 7:51 am
First name: Josh
There’s been a few mentions of the Gore neck joint in this thread. To the best of my knowledge, if we’re talking about a bolt-on neck using a square brass bar embedded in the neck heel, it is actually a Gilet design that dates back quite a ways.
The Gore/Gilet book describes Gilet’s joint and also describes Gore’s further development of the joint which introduces a bolt-down neck extension.
On the actual topic, Tai, I think your new design might not quite hit the mark, for many of the reasons others have outlined, but I respect your willingness to try something new. Keep it up.
PostPosted: Wed Sep 25, 2019 7:54 am
Last Name: Parker
City: Charleston
There are free instructions on the StewMac website on how to build a dovetail jig that holds the parts for routing.
PostPosted: Wed Sep 25, 2019 9:26 am
First name: John "jd"
City: Santa Barbara
Or, it you really hate using a loud, unstable, mistake prone routers ...Try using a hand saw and chisel.
These users thanked the author windsurfer for the post: Colin North (Wed Sep 25, 2019 12:14 pm)
PostPosted: Wed Sep 25, 2019 4:48 pm
a little heating is not going to stop wood from shrinking on RH changes unless you do serious torrification.
These users thanked the author bluescreek for the post: Hesh (Wed Sep 25, 2019 10:28 pm)
PostPosted: Wed Sep 25, 2019 5:28 pm
Online
You can also do a dovetail with hand tools, you can do it on a router table, or a tablesaw. Lots of different ways. Keep an open mind...
PostPosted: Wed Sep 25, 2019 6:12 pm
Tai, can you get your hands on the LMI neck jig? Or plans? Or plans for the Woolson neck jig, since that's basically what it is?
Alternatively, Tom Bills has a dovetail jig in his Luthier's Edge program that would be right up your alley as a machinest.
PostPosted: Wed Sep 25, 2019 6:33 pm
Seems like the Gore Gillet books do a step by step on doing a dovetail by hand (can’t remember the chapter)
PostPosted: Sat Sep 28, 2019 12:15 pm
there are many videos on you tube about this but many do overthink this joint when they start. It is a simple interference joint.
Remember ACE
A angle
set the neck angle first
as you work the cheeks of the heel shim the tenon to tighten don't try adjusting it. AND USE A CLAMP TO PRESS IT IN
C center
Once the angle is set all you have to do is work the cheek of the heel on one side to true the neck to center
E elevation
Now that the neck is in position to angle and center you can work the tenon. Use chalk to mark the block and you can see the chalk , that tells you where you remove wood.
One thing to remember is the you only need the lower 1/3 of the neck tenon to bite and pull the tenon into the neck block. You should not ever really do anything at the neck block other that to chamfer the corners so you don't have the tenon held off and kept from seating.
These users thanked the author bluescreek for the post: Colin North (Sun Sep 29, 2019 2:55 am)
PostPosted: Sun Sep 29, 2019 2:57 am
Thank you Mr Hall for taking the time to post this summary, you have always been very generous with your help and advice.
I might even have a try at a dovetail myself!
PostPosted: Sun Sep 29, 2019 3:42 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
So it sounds like it’s better to make the neck tenon a slightly smaller angle than the pocket in the body? So the dovetail bites towards the bottom side more?
Is wood compression due to string tension even something to be concerned about?
Typhoon Guitars
PostPosted: Sun Sep 29, 2019 6:04 am
IMHO, roughly 10,000,000+ well made dovetails vote NO to wood compression being something to be concerned about.
Just my humble opinion of course.
PostPosted: Tue Oct 22, 2019 4:59 pm
Any update on how this turned out?
PostPosted: Tue Oct 22, 2019 8:06 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Seems to work well, but then again not sure on the long term effects.
Typhoon Guitars
Users browsing this forum: meddlingfool and 21 guests
