It is currently Sat Sep 13, 2025 11:09 am
PostPosted: Fri Oct 18, 2019 1:22 pm
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
Besides the obvious practice, and a mature spray technique is there anything to consider when spraying a transparent toner? I keep getting darker lines when I overlap my passes.
PostPosted: Fri Oct 18, 2019 1:58 pm
Go with a less dense toner and use more coats. You can keep the thickness of these "more coats" thinner by using less lacquer and more thinner.
These users thanked the author Barry Daniels for the post: Conor_Searl (Fri Oct 18, 2019 4:58 pm)
PostPosted: Fri Oct 18, 2019 5:01 pm
First name: Conor
Last Name: Searl
City: Duncan
That makes sense Barry, thanks.
I read elsewhere on this forum someone suggested spraying as a toner dye and straight thinner onto the seal coat. Using a waterbased lacquer system I feel like this would just run all over the place, am I mistaken?
PostPosted: Fri Oct 18, 2019 5:36 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
On a waterbased finish I've mixed the toner in DA and misted many coats for sunburst shading. The sealer and first coats should be flattened before doing it, DAMHIKT. It flashes off pretty fast so the next coats can be done in the same session.
These users thanked the author CarlD for the post: Conor_Searl (Fri Oct 18, 2019 10:21 pm)
PostPosted: Fri Oct 18, 2019 10:33 pm
First name: Conor
Last Name: Searl
City: Duncan
Cool. DA isn't so readily available in Canada, so I haven't bothered trying to track some down, but maybe it will be worth finding.
I did mix up my colour in lacquer to use as the toner, and it worked pretty good when I tested on off cuts, but spraying a guitar body is a lot different than 4" x 18" off cut, and that's where I ran into my streaky issues, although I will say that after it flowed out, dried and took a second coat it looked a lot better. Still some subtle heavy and light spots though. I never did use a sealer on this body, just shot the toner straight onto bare wood, so I may just sand this toner/lacquer back flat, consider that my seal coat and then spray a couple more coats of the toner I mixed but considerably thinned.
PostPosted: Sun Oct 20, 2019 7:20 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Your overlap is incorrect for your fan pattern or your gun isn't set up correct. Have you read my gun set up guide?
https://howardguitars.blogspot.com/2015/06/spray-gun-setup-technique-by-brian.html
Also look here under streaks https://howardguitars.blogspot.com/2015/05/spray-finish-problem-solving-chart_18.html
Brian
These users thanked the author B. Howard for the post: Conor_Searl (Mon Oct 21, 2019 11:49 am)
PostPosted: Sun Oct 20, 2019 10:16 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Informative links, Brian!
Thank you!
Alan
PostPosted: Mon Oct 21, 2019 11:50 am
First name: Conor
Last Name: Searl
City: Duncan
I have, but not in a long time. I'm organized enough now to keep this kind of helpful info where I can find it in the future. Thanks for the reminder Brian.
