It is currently Tue Jul 29, 2025 12:38 am
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Oct 25, 2019 11:03 am
Last Name: Ionta
City: Hopkinton
State: Massachusetts
Zip/Postal Code: 01748
Michaeldc wrote:
Are you guys and gals pre-bending the sides before laminating them together?
Thanks, M
I did prebend. 3 layers (cherry/maple/cherry) each about .040", nested together on the bender. The sides were made from materials on hand in my shop so nothing special but they worked out really well.
These users thanked the author bionta for the post: Michaeldc (Fri Oct 25, 2019 11:16 am)
PostPosted: Fri Oct 25, 2019 5:53 pm
rlrhett wrote:
Ps: what veneers do you use? Do you thin stock on a wide belt sander to your own specs, or are you buying pre made veneer? Do you use standard 1:40” veneers or is there a source for 1/20” or 1/16” veneers of high value wood?
I usually use similar woods with lower grade on the inside. I am usually around .060 outer and .050-.056 inner.
I did have good luck on a couple of Birds Eye Maple guitars with Rosewood inner sides. The tone was well received. I think it kind of took the edge off the Maple.
