It is currently Fri Jul 18, 2025 6:52 pm
PostPosted: Tue Oct 29, 2019 4:54 pm
Could someone who does more building than me (or who has a better memory) remind me... it's the Stew-Mac cutter (and not the LMI version) that gives you more depth, for cutting the purfling and binding channels, correct? Or did LMI go to a deeper cutter as well? Ah... when memory starts to go...
TIA,
Ken
Ken Mitchell
Durham, NC
PostPosted: Tue Oct 29, 2019 5:09 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
If you are asking about the router bearings, The LMI set gives a maximum depth of 0.230" and the StewMac set gives a maximum of 0.210".
PostPosted: Tue Oct 29, 2019 6:41 pm
Hi Jay, no, it's a question of how deep (vertically) the bearings will reach, so you can cut the binding ledge, then cut the purfling ledge without the wheel falling into the first channel. One or the other had an issue with reach, but may have remedied it by now(?). I noticed that SM has a small collar that you can use to get more contact between the wheel and the side. That's the issue that I'm concerned about.
Ken Mitchell
Durham, NC
PostPosted: Tue Oct 29, 2019 6:56 pm
First name: Jay
City: Bothell
State: Washington
Ok, sorry for misunderstanding your question. I don't know which has the larger vertical reach. I've always cut the purfling ledge first and then the binding ledge so the vertical reach isn't a concern for me.
PostPosted: Tue Oct 29, 2019 7:35 pm
First name: Brad
Last Name: Combs
If it helps, the SM one I have has a bushing on it that let’s the bearing ride lower.
Brad
PostPosted: Tue Oct 29, 2019 8:23 pm
Brad, yes, I noticed that. I think I'll go with the SM piece again this time (my first one, years ago, was an SM).
Brad
Ken Mitchell
Durham, NC
Users browsing this forum: Chris Pile, Jim Watts, oval soundhole and 22 guests
