It is currently Sun Jul 27, 2025 7:29 am
PostPosted: Tue Nov 05, 2019 8:05 am
While perusing the CMT router bit offerings I ran into this bit:
https://www.amazon.com/CMT-663-004-11-S ... lp_pl_dp_5
In a previous discussion I mentioned it might be nice to make a safety planer with insert cutters - this might be it! It's intended use is to smooth the spoil boards on CNC machines. The 4 sided carbide insert cutters might make sharpening a thing of the past.
PostPosted: Tue Nov 05, 2019 8:40 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
How well do you think it will cut at drill press speeds? If somebody needs a router bit like this anyway, it sounds like a worthwhile $60 experiment.
PostPosted: Tue Nov 05, 2019 9:06 am
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
There's nothing safe about that thing! wow7-eyes
Hutch
These users thanked the author banjopicks for the post: Ben-Had (Fri Nov 08, 2019 6:28 pm)
PostPosted: Tue Nov 05, 2019 9:09 am
One downside to it is some of the "safety" feature is gone. Rigging up a shield might be a good idea. Another possibility would be to make a jig for a router base and use it in a router. That might make a higher speed surfacing tool than the average safety planer. If the jig incorporated a plunge base and dust collection so much the better - and maybe a mini vacuum table hold down runoff a shop vac.....
After cogitating on the imagineering, using it in a drill press with a simple shield might be the simpler solution. pizza
Hutch posted while I was typing - yes adding the safety back would be a priority.
PostPosted: Wed Nov 06, 2019 6:36 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Here's the tool to use it in:
https://www.woodpeck.com/woodpeckers-slab-flattening-mill.html
Ed
PostPosted: Wed Nov 06, 2019 7:18 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I doubt a drill press will turn enough rpm to get a clean cut, This is designed for use with a planing sled....
https://www.youtube.com/watch?v=bm9SDuWIAk0
Brian
PostPosted: Wed Nov 06, 2019 10:05 am
this tool is also known as a face mill
many here never used one but it will do fine on wood , This set up isn't as robust as a R* collet but It will do well on a cnc machine with a vacuum holding system. I use something like this on a R8 collet. You can flip the inserts for multiple uses. The key is in the feed and cut rate , you should not be taking more that .10 to .015 in per pass and you want to good blow off or dust collection. I can assume your using MDF as a spoil board that this will work fine but will produce a lot of fine dust.
If you are trying to do this with without a proper fixturing system I would say don't use it..
Be aware of the feed direction , and feed rate.
PostPosted: Fri Nov 08, 2019 5:32 pm
I've flattened a few slabs using a face mill with both a sled setup and a CNC. My initial thought was, "Drill press doesn't rotate as fast as the router..." But then I wondered why it shouldn't work anyway. If safety planers and the like work in a drill press, why not a face mill? Is it a mass issue? Face mills have considerably less mass than the safety planer I have from Stew-Mac.
