It is currently Sun Jul 27, 2025 5:58 am
 Post subject: Making a Wells Karol jig
PostPosted: Fri Oct 25, 2019 12:53 pm
First name: Brad
Last Name: Combs
I'm planning to spend some time this weekend making a Wells Karol jig. I watched Chris P's videos, seems straight forward enough. I have an HDPE slab that I think will work. The rest is just hardware store goodies from what I can tell. Anyone build one recently and have any tips or things I should watch for?
PostPosted: Fri Oct 25, 2019 2:05 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
Made mine last year. Tapping threads into the HDPE lasted two tightenings before one stripped. Put in a steel threaded insert and all's well, again. Don't treat the thumbscrews like they're going into metal...
It's been used on three soundholes so far, quite happily. Price was right for the use I had for it.
Peter Havriluk
These users thanked the author phavriluk for the post: bcombs510 (Fri Oct 25, 2019 2:39 pm)
PostPosted: Fri Oct 25, 2019 3:04 pm
I made a sound hole cutting jig using HDPE and I was not happy. The threads stripped immediately. I sort of solved that by then using a bigger thread screw but leaving the smaller hole. I think you should experiment on scraps of the HDPE first. You may find that the best way will be to NOT tap the hole, but just let the screw pull its way through and deform the HDPE as it goes. I haven't used it for a while, but my recollection is that there is no visibility advantage to HDPE, so you could use metal, e.g aluminum.
These users thanked the author wbergman for the post: bcombs510 (Fri Oct 25, 2019 3:07 pm)
PostPosted: Fri Oct 25, 2019 3:58 pm
Online
I've been using one for 3/4 years without any problems, just don't get heavy handed with the screws. They really don't need to be so tight to hold firm.
These users thanked the author Colin North for the post: bcombs510 (Fri Oct 25, 2019 4:35 pm)
PostPosted: Fri Oct 25, 2019 5:16 pm
Mine is going on 5+ years. I'm gentle with the thumbscrews.
These users thanked the author Paul Micheletti for the post: bcombs510 (Fri Oct 25, 2019 5:22 pm)
PostPosted: Fri Oct 25, 2019 5:24 pm
First name: Brad
Last Name: Combs
Ok, the threaded HDPE and issue with stripping described is the thumbscrew that locks onto the rail, correct? I would think that needs to be snug but the threaded rod is also doing something to help keep the base in place, right?
PostPosted: Fri Oct 25, 2019 5:50 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Here's mine.
I put extra screws so one doesn't need to tighten so much.
The Telecaster knob is a nice touch as well!
Alan
These users thanked the author alan stassforth for the post: bcombs510 (Fri Oct 25, 2019 6:15 pm)
PostPosted: Fri Oct 25, 2019 6:03 pm
Mine is 10+ years old, no issues. All threads are 1/4-20.
These users thanked the author SteveSmith for the post: bcombs510 (Fri Oct 25, 2019 6:15 pm)
PostPosted: Fri Oct 25, 2019 7:44 pm
I’m happy with the one I built, but if I had to do it again I would likely just use wood or aluminum. The hype will strip and I don’t think it has any real advantage over any other material.
These users thanked the author kjaffrey for the post: bcombs510 (Fri Oct 25, 2019 10:54 pm)
PostPosted: Fri Oct 25, 2019 10:42 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Delrin for our bases, and no issues after 15 years.
- Beth Brower
These users thanked the author Woodie G for the post: bcombs510 (Fri Oct 25, 2019 10:54 pm)
PostPosted: Sat Oct 26, 2019 12:08 am
I used clear acrylic 13 years ago. It’s still in regular use. Dropped it about ten years ago and broke a chunk off of it; glued it back together with acrylic cement, still going.
I've since added thumbscrews to the threaded beam at the upper part of the photo,
These users thanked the author Pat Foster for the post (total 2): Pmaj7 (Mon Dec 02, 2019 3:29 am) • bcombs510 (Sat Oct 26, 2019 7:19 am)
PostPosted: Sat Oct 26, 2019 9:36 am
Hard maple cuts and holds threads surprising well. I have some 40 year old jigs that get used frequently that still have snug threads.
These users thanked the author Barry Daniels for the post (total 3): Ernie Kleinman (Mon Oct 28, 2019 8:26 am) • James Orr (Sun Oct 27, 2019 9:44 pm) • bcombs510 (Sat Oct 26, 2019 2:20 pm)
PostPosted: Sat Oct 26, 2019 8:05 pm
City: Lawrence
Zip/Postal Code: 66047
Absolutely love delrin. very stable. Teflon would be another good choice.
These users thanked the author Dave Rickard for the post: bcombs510 (Sat Oct 26, 2019 8:31 pm)
PostPosted: Sun Oct 27, 2019 12:51 am
First name: Tim
Last Name: Allen
City: San Francisco
I was just using mine today. I'm very grateful to Chris for his tutorial!
I made mine out of Baltic birch (or some similar birch laminated wood). I thought of it as a prototype, and was going to make another one out of plastic after beta testing this one, but it has worked fine so I just keep using it. If I was going to use it every day I might take the trouble to put in threaded inserts.
Tim Allen
"Never hurry, never rest."
These users thanked the author TimAllen for the post: bcombs510 (Sun Oct 27, 2019 6:40 am)
PostPosted: Sun Oct 27, 2019 4:49 pm
Time to start calling this a “Karol jig”. It was he who created it and kindly posted it. Just because someone drew up plans for Tony’s design shouldn’t give undeserved credit.
These users thanked the author pthes for the post: Robbie_McD (Fri Dec 06, 2019 9:57 am)
PostPosted: Sun Oct 27, 2019 7:09 pm
First name: Brad
Last Name: Combs
Has anyone used or considered using the cordless Dewalt laminate trimmer for this procedure?
Today I used the SM base and a Dremel. I started using a footswitch instead of turning the Dremel off and on because I was slightly tipping the base when turning the router off and on.
I’m thinking with this wider base that tipping won’t be an issue and I would LOVE to not have to battle a cord.
https://www.homedepot.com/p/DEWALT-20-V ... /311387419
Brad
PostPosted: Mon Oct 28, 2019 10:52 am
First name: Tom
Last Name: Rein
City: Saline
In case anyone interested I have a Wells (made by him) Karol circle cutter listed in the classifieds.
Stay with the happy people.
--Reynolds Large
PostPosted: Mon Oct 28, 2019 3:32 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Are the plans from Chris still available? If I have the StewMac thingy, will this be a big improvement? I find that one pretty easy to use.
Ed
PostPosted: Mon Oct 28, 2019 3:40 pm
First name: Brad
Last Name: Combs
Ed
Chris did a series of videos. It doesn't have 100% complete dimensions but there's enough there to figure the rest out.
Part 1:
http://www.youtube.com/watch?v=9oRqUK-CMIo
Part 2:
http://www.youtube.com/watch?v=3eyR9sS5Swo
Part 3:
http://www.youtube.com/watch?v=g92K82cRiyU
Brad
PostPosted: Mon Oct 28, 2019 11:46 pm
First name: Charlton
Last Name: Wang
What happened to Chris? He hasn't been on here in a while and has no recent videos anymore.
PostPosted: Tue Oct 29, 2019 1:51 am
Sylvan has the dimensions and instructions available on his site under the Premium Articles page if anyone is interested.
These users thanked the author James Orr for the post: bcombs510 (Wed Dec 04, 2019 5:55 pm)
PostPosted: Sun Dec 01, 2019 2:27 pm
First name: Brad
Last Name: Combs
Here is what I ended up with. I made some modifications so that the jig would go down small enough to do Uke sound hole and rosettes. It can go 2 1/4” to 9” in size.
The 20V cordless router seems to work great. It stops on a dime! :)
The adapter collet from SM let’s me use the end mills I have been using with the dremel.
Brad
These users thanked the author bcombs510 for the post: Pmaj7 (Mon Dec 02, 2019 3:37 am)
PostPosted: Wed Dec 04, 2019 1:38 pm
First name: Tim
Last Name: Allen
City: San Francisco
Very nice! Thanks for posting it.
Tim Allen
These users thanked the author TimAllen for the post: bcombs510 (Wed Dec 04, 2019 1:43 pm)
PostPosted: Wed Dec 04, 2019 1:49 pm
First name: Brad
Last Name: Combs
No problem. Here's a list of things I had to buy that I didn't have on-hand:
1) #7 Drill bit which is used to drill all the holes which are then tapped with 1/4-20 tap - https://www.amazon.com/gp/product/B004U ... UTF8&psc=1
2) F Drill bit which is used to drill the holes that the rails fit into. The bit is *just* oversized from 1/4" at .257. This lets the rail slide but little slop for the set screws to have to deal with - https://www.amazon.com/gp/product/B004U ... UTF8&psc=1
3) Tele knobs - https://www.amazon.com/gp/product/B001F ... UTF8&psc=1
4) 1/4 - 20 tap - https://www.amazon.com/gp/product/B003A ... UTF8&psc=1
5) HDPE Sheet - https://www.amazon.com/gp/product/B000I ... UTF8&psc=1
The rest is the 1/4" rod, the 1/4-20 threaded rod, the set screws, knobs, 1/4" nuts (need 1 nylon lock nut) are all hardware store goodies.
Hope that helps.
Brad
PostPosted: Wed Dec 04, 2019 5:37 pm
Online
First name: Ken
Last Name: Lewis
City: Mt. Pearl
State: NL
Brad, looking at your pics. above, I'll offer a little suggestion. Maybe put two locking knobs towards the router,
one on each rail and two set screws/grub screws towards the end as these don't need much adjustment in use.
The locking on both rails will heighten the precision of the jig a bit and prevent any movement due to racking.
Btw, nice job on the jig.
These users thanked the author Ken Lewis for the post: bcombs510 (Wed Dec 04, 2019 5:49 pm)
Users browsing this forum: Bing [Bot], Colin North, doncaparker, Ken Lewis and 22 guests
