It is currently Sun Sep 21, 2025 12:52 am
 Post subject: JJB pickup installation.
PostPosted: Fri Dec 13, 2019 6:24 pm
Looking to install a JJB 430-C, 4 transducer pickup system in a classical.
Steel string installation with bridge pin holes to locate transducers is not an issue, but what about when there are no bridge pins?
PostPosted: Fri Dec 13, 2019 7:05 pm
Does the classical have fan bracing? You might be able to use that for left to right placement. Measure the distance from the edge of the soundhole to the saddle, cut a scrap of wood to that length and (gently) clamp (or tape) it inside the guitar to locate the saddle position. Working blind through the soundhole is always fun!
PostPosted: Fri Dec 13, 2019 9:03 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
Maybe this would help...https://kksound.com/pdf/pureclassic.pdf
These users thanked the author CarlD for the post (total 2): Clay S. (Sat Dec 14, 2019 4:36 pm) • Colin North (Fri Dec 13, 2019 9:16 pm)
PostPosted: Fri Dec 13, 2019 9:17 pm
Thanks Carl!
PostPosted: Sat Dec 14, 2019 10:00 am
Using mirrors place a piece of tape, masking tape that you can feel on the center brace the distance back from the sound hole that you want your transducers.
Wipe the bottom of the top on both sides of your tape with accelerator on a paper towel getting it on the underside of the top.
With one drop of superglue, medium on a single transducer reach inside and find your tape. Stick the thing next to that tape, hold for a count of ten and then look with the mirror to be sure it's acceptable. Exact placement is not the goal here but approximate placement is fine.
If your dot of medium CA was small enough you will get your finger back too....... ;)
I like to loop the cable once onto itself too to take up some slack on say a KK. I've never installed one of these that you have.
Next with each subsequent transducer repeat the steps except for wiping with accelerator just move quickly so the initial wiping is usable for all three or four transducers. I can always either feel the tape or the previous transducer and use that placement as a guide to stick the next transducer next to it.
Or, conversely use an LR Baggs Lyric classical and only have one small mic to stick between the fan braces with placement being not at all critical in my experience.
Hope this helps Buddy and Merry Christmas to ya too! :)
These users thanked the author Hesh for the post: Colin North (Sat Dec 14, 2019 10:42 am)
PostPosted: Sat Dec 14, 2019 10:45 am
And the Season's best back to you!
These users thanked the author Colin North for the post: Hesh (Sun Dec 15, 2019 7:12 am)
PostPosted: Sat Dec 14, 2019 4:57 pm
First name: Trevor
Last Name: Gore
City: Sydney
Colin, you may find one or other of these tips useful.
http://www.goreguitars.com.au
These users thanked the author Trevor Gore for the post: Clay S. (Sun Dec 15, 2019 10:04 am)
PostPosted: Sun Dec 15, 2019 8:21 am
Thanks Trevor. Bit of serendipity here.
The "sheep pen" sort of idea came to me last night as I was dropping off.
I've already used something similar to position a Braggs Anthem internal mic on a steel string with narrow bridge plate. Located it with dowels up though the bridge pin holes.
Users browsing this forum: Bing [Bot] and 36 guests
