It is currently Sun Jul 20, 2025 7:08 pm
PostPosted: Sat Dec 21, 2019 10:46 am
Hi All,
I have a project that I have not dealt with before. I received back a guitar I built for a customer a few years ago. I plan to replace the neck, but the finish on the top upper bout has been damaged and in some cases almost completely removed. I don't know how this happened. It looks like someone dumped acetone on it(!). The guitar is a Flamenco blanca and the finish is hand applied spar varnish. I once read an article somewhere about doing such a partial finish restoration by prepping the damaged areas and applying new finish and blend into the undamaged finish by successively thinning subsequent coats. I do not have the article nor do I remember where it came from.
Anyone have experience with with something like this? I would greatly appreciate any input in this regard.
Max Bishop
Max Bishop
Brighton, Michigan
PostPosted: Sat Dec 21, 2019 11:04 am
Max,
It's been some years ago now, but I had success refinishing part of the side of a guitar finished with Epifanes. I don't recall all the details, but I feathered the area and mixed acetone into the varnish, about 5% if I recall, to help the new finish bite. Final sanding went down to 12000 with MicroMesh. Buffer took care of the witness lines.
PostPosted: Sat Dec 21, 2019 11:13 am
Varnish does not burn in so it is difficult to repair. I would do a full refinish, or at least the sides.
PostPosted: Sat Dec 21, 2019 11:46 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Sorry about that, Max.
I agree with Barry.
I can't believe spar varnish would do that,
so, something must have happened to the guitar.
Problems down the line after a build are the reason I don't sell my builds.
Alan
PostPosted: Sat Dec 21, 2019 12:22 pm
Since it is a varnish finish you might research violin finish repair. Spar (long oil) varnishes tend to remain comparatively soft, so you will want to recoat with the same product originally used (best) or one with matching properties.
This video may offer some help:
https://www.youtube.com/watch?v=jbE-Sl_IIDM
PostPosted: Sat Dec 21, 2019 1:43 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
If it is a true "Spar" varnish it should be able to be wetted out and blended with new. Typically gum spirits or turpentine are used with traditional spar varnish.
Brian
PostPosted: Mon Dec 23, 2019 1:35 pm
Hi Brian,
Yes, it's Petit Captain's Varnish. What do you mean by "wetted out"?
Max Bishop
Brighton, Michigan
PostPosted: Tue Dec 24, 2019 7:41 am
Last Name: Howard
City: Magnolia
State: Delaware
One of the first steps to a seamless repair of these materials is re-hydrating the original film or "wetting out" as they used to say in the trade. On old Nitro we typically spray a bit of retarder to prep the old material to bond with the new at a molecular level.
In the case of a real varnish that would entail cleaning any contaminates off the surface followed by a thorough scuff with some fine steel wool ( or equivalent) and then gently moistened with spirits (typically gum turpentine). This returns the original film to the state it would have been in at any re-coat window in the original finish schedule. This then allows the resins to amalgamate in the same manner as original.
The problem will be if you do not have the exact same varnish..... due to variables in varnishes the coloration between brands is considerable and even differences between batches can be quite noticeable.
Brian
PostPosted: Tue Dec 24, 2019 2:32 pm
Thanks to all for your input. perhaps I'll post a picture of the finished (or "refinished") product.
Max
Max Bishop
Brighton, Michigan
