It is currently Mon Jul 21, 2025 3:23 am
PostPosted: Sun Dec 29, 2019 1:18 pm
Anyone built and used a Fret Buttress Jig Drawings by Luthier's CoolTools?
Just wondering how much support you get from the birch ply arms from the shock load of a dead-blow hammer on the FB extension.
PostPosted: Sun Dec 29, 2019 2:07 pm
Hey Colin - this has been brought up here before and since physics doesn't change neither will my answer. :)
As you already suspect the shop made fret buck doesn't have the mass of the commercial ones. We have the Taylor one and although I'm home at the moment it's around 30 pounds IIRC. It's this mass that counters and resists the hammer blows.
The very concept of making one out of wood says to me that the designer did not understand the physics of how the mass of the commercial bucks resist the hammer shock and blows. The wooden one will still have the clamping affect but not the mass to resit the blows.
I would not trust it with the valuable personal property of others (or myself).
These users thanked the author Hesh for the post (total 2): Pmaj7 (Thu Jan 02, 2020 3:07 am) • dpetrzelka (Mon Dec 30, 2019 7:02 am)
PostPosted: Sun Dec 29, 2019 2:48 pm
FWIW, I use a small ziplock bag filled with birdshot which is duct taped like snot to form a tight but loose little bundle of shock absorbing goodness. I hold it inside under the extension when fretting and it does a great job of absorbing the hammer shock. Much less cumbersome than the fret buck and much less likely to ding the soundhole...
These users thanked the author meddlingfool for the post: Pmaj7 (Thu Jan 02, 2020 3:07 am)
PostPosted: Sun Dec 29, 2019 3:05 pm
FWIW that's what I've been doing. Works OK but I feel a little risky as I need one hand to lift the shot bag and guitar and the other to hammer, in a small shop.
PostPosted: Sun Dec 29, 2019 3:07 pm
Hesh, pretty much as I suspected, I've ordered a buck from stewmac, $50 off just now.
These users thanked the author Colin North for the post: Hesh (Mon Dec 30, 2019 3:18 pm)
PostPosted: Sun Dec 29, 2019 4:53 pm
The two things that work for me are a handheld block of wood or a bean bag under the extension, and a fret tang that has been thinned down a bit so you don't have to hammer as hard. I thin the barbs down with a homemade fret barber.
These users thanked the author Barry Daniels for the post: Pmaj7 (Thu Jan 02, 2020 3:09 am)
PostPosted: Sun Dec 29, 2019 8:41 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
I’ve had my eye on that gizmo for a while and spotted the year-end sale. Trouble is, I’m currently vacationing in NZ and won’t be able to accept shipment (at a border receiver in Vermont) for another 3 weeks. I’ve contacted SM to see if they’ll delay shipping while honouring the price. If not, I guess I’ll wait.
PostPosted: Sun Dec 29, 2019 9:59 pm
Lead shot bag - works great because it works on all guitars. Everything. And no chance of damaging anything while wielding 30 lbs of steel around multi thousand dollar instruments. I did build the fret buttress, which worked fine. I have used the Taylor tool, works well. In a busy repair shop with a great variety of guitars, I have found the bean bag to be hands down the best solution. To make the bean bag, a heavy bag can be used (like a small ziplock, or a few of them), you can wrap or seal with duct tape, and place in an old sock and tie off.
PostPosted: Mon Dec 30, 2019 3:25 pm
If I need to "tap" a fret in I get a small lead block that we keep around after putting on a nitrile glove while handling lead. It's over kill I know but I'm Felix Unger here so I wash my hand as soon as the block gets put away.
But what I wanted to add since that's why I'm posting is that we press frets even over the neck block and on the extension of an acoustic guitar. The students here on the OLF that we've had to our place know what I am talking about because they pressed their frets too. We have created a few simple jigs that are already pictured here on the OLF that permit us to use the SM fret press at any point on an acoustic guitar's fret board. So with this methodology no fret buck or lead block or any other method is required for us to press our frets home, bill the client, next.
The buck is from the days before folks were pressing frets and our's rarely gets used.
PostPosted: Mon Dec 30, 2019 3:54 pm
And I've had someone else saying the buck is a blessing when he has a refret on a multi thousand $ Martin to do.
I have been using a bag of shot for years, but find waving a guitar about with the bag inside, keeping a fret tang vertical and hammering the fret in in a crowded shop a little nerve-wracking.
Just want to try the buck.
PostPosted: Mon Dec 30, 2019 4:28 pm
FWIW I make those fret slots wider and glue them in with fish glue and just a few gentle taps. I used to hold a block of steel in there but it just felt too risky. The shot bags sound like a good idea as they ill conform to the bracing.
These users thanked the author jfmckenna for the post: Barry Daniels (Wed Jan 01, 2020 11:15 am)
PostPosted: Mon Dec 30, 2019 11:04 pm
Colin, that makes sense. I'm not sure about the waving guitar around, at least that is not how I do it. When over the body, I set the fret at the fretboard edge with a light tap. This aligns the fret to slot. I then simply run my hand inside (I just leave the shot bag in there), lift up the bag, and tap away. Guitar lays on the bench (carpet sample for the body, and gun barrel rest at the neck). It's fast, smooth, and uneventful. I've used this method on a few hundred guitars, of every type imaginable - some 100 years old. Never had an issue. I should also mention that I always set my frets with 192g hot hide glue (belt and suspenders). On classical partials, I often chop off half the tang and set with CA. No point in driving off a chunk of ebony fretboard.
PostPosted: Tue Dec 31, 2019 12:00 am
Lead shot bag for me too. Widen the slot slightly with the triangular file. I do lift the guitar off the bench while hammering.
PostPosted: Wed Jan 01, 2020 11:11 am
Thanks guys, I have, as I said earlier, been using a bag of shot for several years. Use fish glue in the the slots with the edges eased, and reduce Tang widths as necessary on the FB extension.
Just want to try an alternative method, if it don't work for me, I'll ditch it.
PostPosted: Wed Jan 01, 2020 12:55 pm
First name: David
Last Name: Scheckman
City: Plainfield
State: VT
Zip/Postal Code: 05667
I’m wondering what size lead bag folks use? How heavy?
David
PostPosted: Wed Jan 01, 2020 3:12 pm
1 kg, 2.2 lbs here.
PostPosted: Wed Jan 01, 2020 5:28 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Here's one other option for a weight under the fretboard extension to absorb hammer blows. It's a sheet metal dolly that weighs 1 3/4 lb. The narrow flat face (which is actually very slightly convex) goes against the underside of the top. It's compact enough that I can wrap my left hand fingers around the curved end of the dolly to hold it in place under the fretboard extension while extending my left thumb over the fretboard to hold a fret in position while setting it with the first wack with the hammer. I got it at a local hardware store.
These users thanked the author J De Rocher for the post: Pmaj7 (Thu Jan 02, 2020 3:22 am)
