It is currently Tue Jul 22, 2025 4:54 pm
 Post subject: Humidity and Back Braces
PostPosted: Thu Apr 16, 2020 11:12 am
First name: Gary
Last Name: Leddington
So i was in my own world today gluing back braces on and when i realised i hadnt checked the humidity... it turned out to be 35% and i had already finished gluing.
How much of a problem is this? Should i be stripping of the braces and starting again when at 45%??
Thanks.
G.
PostPosted: Thu Apr 16, 2020 11:24 am
City: U.P.
I build the box in ~35% RH on purpose. I believe greater risk is in higher RH conditions as that would put the plates in shrink mode more often than compression on average. The shrinking causes cracks.
Brian R
Brian R, Wood Mechanic
N8ZED
These users thanked the author rbuddy for the post: Fasterthanlight (Sat Apr 18, 2020 3:03 pm)
PostPosted: Thu Apr 16, 2020 11:51 am
For back braces it shouldn't be too much of a problem (it's only 10 points off what many people suggest bracing at). For soundboards it might be good to brace closer to 45 -50% R.H. as the swelling and shrinking affects the action on a lightly built "responsive" guitar.
These users thanked the author Clay S. for the post: Fasterthanlight (Sat Apr 18, 2020 3:04 pm)
PostPosted: Thu Apr 16, 2020 12:00 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Agreed. If you are going to vary from the 40-45% range while doing a glue-up of guitar parts, it is better to build too dry than too wet. Swelling tends to cause fewer serious problems than shrinking.
These users thanked the author doncaparker for the post: Fasterthanlight (Sat Apr 18, 2020 3:04 pm)
PostPosted: Thu Apr 16, 2020 12:09 pm
Thanks.
G.
No worries at, you're only 8 deg. low in my book - high/normal RH and then drying out, now that can be potato chip time....
These users thanked the author Colin North for the post: Fasterthanlight (Sat Apr 18, 2020 3:03 pm)
PostPosted: Thu Apr 16, 2020 12:43 pm
First name: Terry
Agreed. I live in Florida, and it's "never" dry... but I had a top that got braced on a day when the weather was unusually nice and I didn't realize the humidity was around 27%. Couple days later the thing wouldn't lay flat in the solera for nothing. Had to put it back in the go deck and heat up the braces until they "slid" a little. But, this is why we use hide glue! Guitar ended up sounding great with no problems.
PostPosted: Fri Apr 17, 2020 2:03 am
First name: Gary
Thanks guys... so what i'm hearing is, it shouldnt be a problem.. go ahead. Better a bit too dry that too wet?
G.
www.leddingtonguitars.com
PostPosted: Fri Apr 17, 2020 6:35 am
Yep
These users thanked the author SteveSmith for the post: Fasterthanlight (Sat Apr 18, 2020 3:03 pm)
PostPosted: Sat Apr 18, 2020 12:44 pm
Last Name: Beaver
City: Lake Forest
I prefer to make and install my braces during low RH times. 30-35 percent sounds like a good time to me.
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: Fasterthanlight (Sat Apr 18, 2020 3:03 pm)
Users browsing this forum: ChuckB, JimKlingshirn, Stuart Flavell and 33 guests
